hello everyone, I want to upload a sketch to my arduino but it won't compile it.
Arduino:1.8.15 (Windows 7), Board:"Arduino Uno"
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\EasyDrivers.cpp: In function 'instruments::EasyDrivers::resetAll()':
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\EasyDrivers.cpp:299:27: warning: iteration 2 invokes undefined behavior [-Waggressive-loop-optimizations]
currentState[stepPin] = LOW;
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\EasyDrivers.cpp:297:29: note: within this loop
for (byte d=FIRST_DRIVER;d<=LAST_DRIVER;d++) {
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp: In member function 'virtual void instruments::ShiftedFloppyDrives::setup()':
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp:39:5: error: 'SPI' was not declared in this scope
SPI.begin();
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp:39:5: note: suggested alternative: 'SPIE'
SPI.begin();
SPIE
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp:40:58: error: 'SPI_MODE0' was not declared in this scope
SPI.beginTransaction(SPISettings(16000000, LSBFIRST, SPI_MODE0)); // We're never ending this, hopefully that's okay...
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp:40:26: error: 'SPISettings' was not declared in this scope
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp: In static member function 'static void instruments::ShiftedFloppyDrives::shiftBits()':
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp:206:5: error: 'SPI' was not declared in this scope
SPI.transfer(directionBits);
G:\Moppy2-2.1.0\Moppy2-2.1.0\Microcontroller\Moppy2-Arduino\src\MoppyInstruments\ShiftedFloppyDrives.cpp:206:5: note: suggested alternative: 'SPIE'
SPIE
exit status 1
Fout bij het compileren voor board Arduino Uno
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
and here is my sketch:
/ __ __ /
/ | \ / | ___ _ __ _ __ _ _ /
/ | |/| |/ _ | '_ | '_ | | | | /
/ || ||_/| ./| ./ _, | /
/ | | | | __/ | /
/* This file left intentionally blank to appease the Arduino IDE.
- FOR GENERAL CONFIGURATION OPTIONS SEE MoppyConfig.h
- See src/main.cpp for the top level code. Functional
- code files can be found in the src folder in the sketch directory, but
- these should be opened using a text editor or different IDE as
- the Arduino IDE does weird things if you start trying to use
- sub-directories.
#include <Arduino.h>
#include "MoppyConfig.h"
#include "MoppyInstrument.h"
- MoppyInstruments handle the sound-creation logic for your setup. The
- instrument class provides a systemMessage handler function and a deviceMessage
- handler function for handling messages received by the network and a tick
- function for precise timing events.
- Configure the appropriate instrument class for your setup in MoppyConfig.h
// Floppy drives directly connected to the Arduino's digital pins
#ifdef INSTRUMENT_FLOPPIES
#include "FloppyDrives.h"
MoppyInstrument *instrument = new instruments::FloppyDrives();
#endif
// EasyDriver stepper motor driver
#ifdef INSTRUMENT_EASYDRIVER
#include "EasyDrivers.h"
MoppyInstrument *instrument = new instruments::EasyDrivers();
#endif
// L298N stepper motor driver
#ifdef INSTRUMENT_L298N
#include "L298N.h"
MoppyInstrument *instrument = new instruments::L298N();
#endif
// A single device (e.g. xylophone, drums, etc.) connected to shift registers
#ifdef INSTRUMENT_SHIFT_REGISTER
#include "ShiftRegister.h"
MoppyInstrument *instrument = new instruments::ShiftRegister();
#endif
// Floppy drives connected to 74HC595 shift registers
#ifdef INSTRUMENT_SHIFTED_FLOPPIES
#include "ShiftedFloppyDrives.h"
MoppyInstrument *instrument = new instruments::ShiftedFloppyDrives();
#endif
- MoppyNetwork classes receive messages sent by the Controller application,
- parse them, and use the data to call the appropriate handler as implemented
- in the instrument class defined above.
- Configure the appropriate networking class for your setup in MoppyConfig.h
// Standard Arduino HardwareSerial implementation
#ifdef NETWORK_SERIAL
#include "MoppySerial.h"
MoppySerial network = MoppySerial(instrument);
#endif
//// UDP Implementation using some sort of network stack? (Not implemented yet)
#ifdef NETWORK_UDP
#include "MoppyUDP.h"
MoppyUDP network = MoppyUDP(instrument);
#endif
//The setup function is called once at startup of the sketch
// Call setup() on the instrument to allow to to prepare for action
instrument->setup();
// Tell the network to start receiving messages
network.begin();
// The loop function is called in an endless loop
// Endlessly read messages on the network. The network implementation
// will call the system or device handlers on the intrument whenever a message is received.
network.readMessages();
can someone help me out please?
