Hello, I hope someone can help me out!
I wanted to try out the new grove kit v3 with the first tutorial, lcd display with hello world text, and a compiling error occurs, for the reason that “wire.h” and the lcd file can not be connected, but I wonder why…
this is the file:
Hello World.ino
2013 Copyright (c) Seeed Technology Inc. All right reserved.
Author:Loovee
2013-9-18
Grove - Serial LCD RGB Backlight demo.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <Wire.h>
#include “rgb_lcd.h”
rgb_lcd lcd;
const int colorR = 255;
const int colorG = 0;
const int colorB = 0;
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
// Print a message to the LCD.
lcd.print(“hello, world!”);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
delay(100);
END FILE
and this is the problem text:
Arduino: 1.6.13 (Mac OS X), Board: “Arduino/Genuino Uno”
/Users/mac/Downloads/Arduino 2.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware -hardware /Users/mac/Library/Arduino15/packages -tools /Users/mac/Downloads/Arduino 2.app/Contents/Java/tools-builder -tools /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr -tools /Users/mac/Library/Arduino15/packages -built-in-libraries /Users/mac/Downloads/Arduino 2.app/Contents/Java/libraries -libraries /Users/mac/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10613 -build-path /var/folders/rp/9j4l8zs96bb_h93qtv_r760c0000gn/T/arduino_build_542402 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr -verbose /Users/mac/Documents/Arduino/Grove_LCD_RGB_Backlight-master/examples/HelloWorld/HelloWorld.ino
/Users/mac/Downloads/Arduino 2.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware -hardware /Users/mac/Library/Arduino15/packages -tools /Users/mac/Downloads/Arduino 2.app/Contents/Java/tools-builder -tools /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr -tools /Users/mac/Library/Arduino15/packages -built-in-libraries /Users/mac/Downloads/Arduino 2.app/Contents/Java/libraries -libraries /Users/mac/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10613 -build-path /var/folders/rp/9j4l8zs96bb_h93qtv_r760c0000gn/T/arduino_build_542402 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr -verbose /Users/mac/Documents/Arduino/Grove_LCD_RGB_Backlight-master/examples/HelloWorld/HelloWorld.ino
Using board ‘uno’ from platform in folder: /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr
Using core ‘arduino’ from platform in folder: /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr
Detecting libraries used…
“/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10613 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino” “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard” “/var/folders/rp/9j4l8zs96bb_h93qtv_r760c0000gn/T/arduino_build_542402/sketch/HelloWorld.ino.cpp” -o “/dev/null”
“/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10613 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino” “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard” “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src” “/var/folders/rp/9j4l8zs96bb_h93qtv_r760c0000gn/T/arduino_build_542402/sketch/HelloWorld.ino.cpp” -o “/dev/null”
“/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10613 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino” “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard” “-I/Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src” “/var/folders/rp/9j4l8zs96bb_h93qtv_r760c0000gn/T/arduino_build_542402/sketch/HelloWorld.ino.cpp” -o “/var/folders/rp/9j4l8zs96bb_h93qtv_r760c0000gn/T/arduino_build_542402/preproc/ctags_target_for_gcc_minus_e.cpp”
/Users/mac/Documents/Arduino/Grove_LCD_RGB_Backlight-master/examples/HelloWorld/HelloWorld.ino:26:21: fatal error: rgb_lcd.h: No such file or directory
compilation terminated.
Bibliothek Wire in Version 1.0 im Ordner: /Users/mac/Downloads/Arduino 2.app/Contents/Java/hardware/arduino/avr/libraries/Wire wird verwendet
exit status 1
Fehler beim Kompilieren für das Board Arduino/Genuino Uno.
Thank you for your help!
