Not simple enough it seems! I've given it a go but I can't seem to figure out how to change the code to get this to work. This is the code, if it means anything:
// Test code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code just echos whatever is coming from the GPS unit to the
// serial monitor, handy for debugging!
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
// ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// Connect the GPS TX (transmit) pin to Digital 8
// Connect the GPS RX (receive) pin to Digital 7
// You can change the pin numbers to match your wiring:
SoftwareSerial mySerial(8, 7);
#define PMTK_SET_NMEA_UPDATE_1HZ "$PMTK220,1000*1F"
#define PMTK_SET_NMEA_UPDATE_5HZ "$PMTK220,200*2C"
#define PMTK_SET_NMEA_UPDATE_10HZ "$PMTK220,100*2F"
// turn on only the second sentence (GPRMC)
#define PMTK_SET_NMEA_OUTPUT_RMCONLY "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
// turn on GPRMC and GGA
#define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn on ALL THE DATA
#define PMTK_SET_NMEA_OUTPUT_ALLDATA "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn off output
#define PMTK_SET_NMEA_OUTPUT_OFF "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
#define PMTK_Q_RELEASE "$PMTK605*31"
while (!Serial); // wait for Serial to be ready
Serial.begin(115200); // The serial port for the Arduino IDE port output
mySerial.begin(9600);
delay(2000);
Serial.println("Software Serial GPS Test Echo Test");
// you can send various commands to get it started
//mySerial.println(PMTK_SET_NMEA_OUTPUT_RMCGGA);
mySerial.println(PMTK_SET_NMEA_OUTPUT_ALLDATA);
mySerial.println(PMTK_SET_NMEA_UPDATE_1HZ);
Serial.println("Get version!");
mySerial.println(PMTK_Q_RELEASE);
if (Serial.available()) {
char c = Serial.read();
Serial.write(c);
mySerial.write(c);
if (mySerial.available()) {
char c = mySerial.read();
Serial.write(c);
