Compiling Error for Arduino Uno Board
Hello,
I am new to using arduino boards and need help finding what the error is. This code comes up while I am trying to test a DHT 22 temperature Sensor. I will attach the error code below. I am using an Arduino nano board and OSEPP UNO R3 Plus Board and come up to the same error. Please I need help figuring this out. Please and Thank you.
Arduino: 1.8.10 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\aydan\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0403_6001 -ide-version=10810 -build-path C:\Users\aydan\AppData\Local\Temp\arduino_build_630878 -warnings=none -build-cache C:\Users\aydan\AppData\Local\Temp\arduino_cache_257533 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\aydan\Documents\Arduino\sketch_nov22a\sketch_nov22a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\aydan\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0403_6001 -ide-version=10810 -build-path C:\Users\aydan\AppData\Local\Temp\arduino_build_630878 -warnings=none -build-cache C:\Users\aydan\AppData\Local\Temp\arduino_cache_257533 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\aydan\Documents\Arduino\sketch_nov22a\sketch_nov22a.ino
Using board ‘uno’ from platform in folder: C:\Program
Using core ‘arduino’ from platform in folder: C:\Program
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\aydan\AppData\Local\Temp\arduino_build_630878\sketch\sketch_nov22a.ino.cpp” -o nul
Alternatives for DHT.h: [DHT_sensor_library@1.3.8 DHT-sensor-library-master@1.3.8]
ResolveLibrary(DHT.h)
→ candidates: [DHT_sensor_library@1.3.8 DHT-sensor-library-master@1.3.8]
panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x0 pc=0x7855fb]
goroutine 1 [running]:
github.com/arduino/arduino-cli/legacy/builder.ResolveLibrary(0x11ce85a0, 0x11f71c41, 0x5, 0x11f71c41)
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-cli/legacy/builder/resolve_library.go:64 +0x14b
github.com/arduino/arduino-cli/legacy/builder.findIncludesUntilDone(0x11ce85a0, 0x11f25820, 0x88ed00, 0x11db6690, 0x11c072f8, 0x11d3b600, 0x0)
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-cli/legacy/builder/container_find_includes.go:358 +0x3b6
github.com/arduino/arduino-cli/legacy/builder.(*ContainerFindIncludes).Run(0xdebc68, 0x11ce85a0, 0xdebc68, 0x0)
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-cli/legacy/builder/container_find_includes.go:152 +0x3e5
github.com/arduino/arduino-cli/legacy/builder.runCommands(0x11ce85a0, 0x11c79e1c, 0x20, 0x20, 0x409a01, 0x3ffff, 0x0)
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-cli/legacy/builder/builder.go:210 +0xbd
github.com/arduino/arduino-cli/legacy/builder.(*Builder).Run(0x11c81f40, 0x11ce85a0, 0xdebbb4, 0x11c52c78)
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-cli/legacy/builder/builder.go:117 +0xb9c
github.com/arduino/arduino-cli/legacy/builder.RunBuilder(...)
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-cli/legacy/builder/builder.go:226
main.main()
/home/jenkins/workspace/arduino-builder-all-cross-cli-inception/src/github.com/arduino/arduino-builder/main.go:398 +0x6d2
C:\Program Files (x86)\Arduino\arduino-builder returned 2
Error compiling for board Arduino/Genuino Uno.
DHT-22.ino (987 Bytes)
I believe this is caused by a bug in Arduino IDE 1.8.10. Please try using Arduino IDE 1.8.9 instead. You can download it here: https://www.arduino.cc/en/Main/OldSoftwareReleases#previous
