I keep getting this error when compiling on my Arduino micro. I am trying to send messeges between two Arduinos using a nrf24l01. Thanks for any help you can provide.
- This is a verbose output
Sketch uses 3514 bytes (12%) of program storage space. Maximum is 28672 bytes.
Global variables use 157 bytes (6%) of dynamic memory, leaving 2403 bytes for local variables. Maximum is 2560 bytes.
Performing 1200-bps touch reset on serial port COM3
Waiting for upload port...
Upload port found on COM4
avrdude: Version 6.3-20190619
C"C:\Users\Cyrus\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Cyrus\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega32u4 -cavr109 "-PCOM4" -b57600 -D "-Uflash:w:C:\Users\Cyrus\AppData\Local\Temp\arduino-sketch-2EC112726A372CBA9A55B155AECEA1E2/Reciever.ino.hex:i"
opyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Cyrus\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\Cyrus\AppData\Local\Temp\arduino-sketch-2EC112726A372CBA9A55B155AECEA1E2/Reciever.ino.hex"
avrdude: writing flash (3514 bytes):
Writing | ################################################## | 100% 0.27s
avrdude: 3514 bytes of flash written
avrdude done. Thank you.
