I commented the 2 sections from that commit in my local library. Now I have this error:
sketch/GxEPD_Example2.ino.cpp.o:(.literal._Z5setupv+0x3c): undefined reference to `GxDEPG0213BN::init(unsigned int)'
sketch/GxEPD_Example2.ino.cpp.o:(.literal._Z5setupv+0x44): undefined reference to `GxDEPG0213BN::fillScreen(unsigned short)'
sketch/GxEPD_Example2.ino.cpp.o:(.literal._Z5setupv+0x58): undefined reference to `GxDEPG0213BN::update()'
sketch/GxEPD_Example2.ino.cpp.o:(.literal._Z14drawCornerTestv+0x0): undefined reference to `GxDEPG0213BN::drawCornerTest(unsigned char)'
sketch/GxEPD_Example2.ino.cpp.o:(.literal._Z4loopv+0xc): undefined reference to `GxDEPG0213BN::powerDown()'
sketch/GxEPD_Example2.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_io+0x8): undefined reference to `GxIO_SPI::GxIO_SPI(SPIClass&, signed char, signed char, signed char, signed char)'
But the files bellow do contain the init function fine:
/Users/xxxxx/Arduino/libraries/GxEPD-lewisxhe/GxEPD.h (to pick one file as example)
But I needed to copy the full repository, including the "src" folder, to look like this:
/Users/xxxxx/Arduino/libraries/GxEPD-lewisxhe/src/GxEPD.h (to pick one file as example)
This is what I have in my folder now, after renaming GxEPD-lewisxhe to GxEPD:
libraries ls -la GxEPD
total 1112
drwxr-xr-x@ 13 levy staff 416 Feb 5 21:42 .
drwxr-xr-x@ 33 levy staff 1056 Feb 5 21:42 ..
drwxr-xr-x@ 13 levy staff 416 Feb 5 21:42 .git
-rw-r--r--@ 1 levy staff 841 Feb 5 21:42 CONTRIBUTING.md
-rw-r--r--@ 1 levy staff 2893 Feb 5 21:42 ConnectingHardware.md
-rw-r--r--@ 1 levy staff 35141 Feb 5 21:42 LICENSE
-rw-r--r--@ 1 levy staff 500090 Feb 5 21:42 MyEPDs_UpdateInfos.pdf
-rw-r--r--@ 1 levy staff 8886 Feb 5 21:42 README.md
drwxr-xr-x@ 15 levy staff 480 Feb 5 21:42 examples
drwxr-xr-x@ 3 levy staff 96 Feb 5 21:42 extras
-rw-r--r--@ 1 levy staff 448 Feb 5 21:42 issue_template.md
-rw-r--r--@ 1 levy staff 460 Feb 5 21:42 library.properties
drwxr-xr-x@ 51 levy staff 1632 Feb 5 21:45 src
Conclusion: the Arduino IDE was able to locate GxDEPG0213BN/GxDEPG0213BN.h but not GxDEPG0213BN/GxDEPG0213BN.cpp. Apparently *.cpp files needs to be within a "src" folder.
I have tried to run the newer version of LilyGo 2.13 ePaper display DEPG021BN with GxEPD2 from ZinggJM (which works very well for the prior version from 2019 using GxEPD_213_B73). With the newer version (DEPG021BN) I tried GxEPD2_213_B74 which displays fine but I was not able to do partial update. Hints very welcome.
So I ended up here trying lewisxhe/GxEPD and got the same problem as described in this thread. I had some troubles understanding what is part of the solution and what is not. So I summarize my findings here:
I am working on a Debian Linux system using Arduino 1.8.13 from arduino.cc
I started with an emty test sketchbook folder and git clone
1) mkdir -p ~/sketchbook_LILYGO-T5_test/libraries/
cd ~/sketchbook_LILYGO-T5_test/libraries/
git clone https://github.com/lewisxhe/GxEPD.git
2) installed Adafruit GFX Library with Arduino Library Manager
let it install Adafruit BusIO
3) uncommented line 7 in file PartialUpdateExample.ino
#define LILYGO_T5_V213
4) tried to compile GxEPD PartialUpdateExample and got:
In file included from /home/dada/sketchbook_LILYGO-T5_test/libraries/GxEPD/src/GxEPD.h:20:0,
from /home/dada/sketchbook_FOREIGN/libraries/GxEPD/examples/PartialUpdateExample/PartialUpdateExample.ino:17:
/home/dada/sketchbook_LILYGO-T5_test/libraries/GxEPD/src/GxFont_GFX.h:77:13: error: 'int16_t GxFont_GFX::getUTF8Width(const char*)' cannot be overloaded
int16_t getUTF8Width(const char *str);
/home/dada/sketchbook_LILYGO-T5_test/libraries/GxEPD/src/GxFont_GFX.h:45:13: error: with 'int16_t GxFont_GFX::getUTF8Width(const char*)'
5) git log --pretty=oneline --abbrev-commit
(HEAD -> master, origin/master, origin/HEAD)
Merge pull request #1 from pianojockl/master
11c9aa1 Added GxDEPG0097BW
21c5430 Added depend
6a) solution 1 If you use git
git checkout 11c9aa1
HEAD is now at 11c9aa1 Added GxDEPG0097BW
PartialUpdateExample compiles fine and runs without problems :)
6b) If you do not want to use git just comment the lines
from the bad last commit out to look like this:
file libraries/GxEPD/src/GxFont_GFX.cpp lines 68-71
// int16_t GxFont_GFX::getUTF8Width(const char *str)
// return _U8G2_FONTS_GFX.getUTF8Width(str);
and file libraries/GxEPD/src/GxFont_GFX.cpp line 45
// int16_t getUTF8Width(const char *str);
Problem solved :)
The problem came from commit c5b9292 as ZinggJM indicates in answer #2.
I did not have to change anything in the file tree regarding 'src/' directory.
PS: I still would prefer to use GxEPD2 from ZinggJM to use the same code as I do for the older board version. Why can't I do partial update on DEPG021BN boards as I did with the older board version?
The panel of your display doesn't come from Good Display. It has no differential refresh waveform table in OTP. This is the same issue as with the 2.9" V2 version from Waveshare:
You could persuade LiliGo to provide me with a free sample.
Or you can either modify the class GxEPD2_290_T94_V2 for use with your display (WIDTH, HEIGHT,?..), or add the differential refresh wavetable from GxEPD2_290_T94_V2 to GxEPD2_213_B74.
Jean-Marc
Edit:
If a topic is marked solved, it is better practice to start a new topic, instead of hijacking it.
Then you can provide a title that better matches your issue or question.
Great suggestion Jean-Marc, i just did what you said and after modifying those files (GxEPD2_290_T94_V2.cpp, GxEPD2_290_T94_V2.h) , changing size and timing in .h file renaming to GxEPD2_213_BN and inserting the relevant include in GxEPD2_BW.h all the examples worked like a charm (just using new selection style and adding the proper define in GxEPD2_selection_check.h for each example)
