Compiling Error - Please Help :)
Hey there,
I was trying to verify the code below before uploading to test it, but I keep getting an ERROR compiling message. Some are warnings (done some research and some people say to leave it, others say to fix it). Just wondering if someone could point me in the right direction. Cheers!
ERRORS/Warnings Below
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all
C:\Users\Kyle\Desktop\best_working_code_yet\best_working_code_yet.ino: In function 'void gsm_init()':
C:\Users\Kyle\Desktop\best_working_code_yet\best_working_code_yet.ino:229:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if(Serial.find("OK"))
C:\Users\Kyle\Desktop\best_working_code_yet\best_working_code_yet.ino:246:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Kyle\Desktop\best_working_code_yet\best_working_code_yet.ino:263:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if(Serial.find("+CPIN: READY"))
c:\users\kyle\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\bin../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: unable to rename 'core\core.a'; reason: File exists
exit status 1
Error compiling for board Arduino/Genuino Uno.
Code is as follows
#include<EEPROM.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,6,5,4,3,2);
int led=13;
#define pulsein 8
#define relay 12
unsigned int pusle_count=0;
float units=0;
unsigned int dollars=0;
float watt_factor=0.3125;
unsigned int temp=0,i=0,x=0,k=0;
char str[70],flag1=0,flag2=0;
String bal="";
lcd.begin(16,2);
pinMode(led, OUTPUT);
pinMode(pulsein, INPUT);
pinMode(relay, OUTPUT);
digitalWrite(pulsein, HIGH);
lcd.setCursor(0,0);
lcd.print("Automatic Energy");
lcd.setCursor(0,1);
lcd.print(" Meter ");
delay(2000);
lcd.clear();
lcd.print("GSM Initilizing...");
gsm_init();
lcd.clear();
lcd.print("System Ready");
Serial.println("AT+CNMI=2,2,0,0,0");
init_sms();
send_data("System Ready");
send_sms();
digitalWrite(led, LOW);
lcd.clear();
// EEPROM.write(1,0);
// dollars=EEPROM.read(1);
serialEvent();
units=dollars/5.0;
lcd.setCursor(0,0);
lcd.print("Units:");
lcd.print(units);
lcd.print(" ");
lcd.setCursor(0,1);
if(dollars<15)
lcd.print("LOW Balance:");
lcd.print("Balance:");
lcd.print(dollars);
lcd.print(" ");
read_pulse();
check_status();
if(temp==1)
decode_message();
send_confirmation_sms();
void serialEvent()
while(Serial.available())
char ch=(char)Serial.read();
str[i++]=ch;
if(ch == '*')
temp=1;
lcd.clear();
lcd.print("Message Received");
void init_sms()
Serial.println("AT+CMGF=1");
delay(200);
Serial.println("AT+CMGS="+918287114222"");
delay(200);
void send_data(String message)
Serial.println(message);
delay(200);
void send_sms()
Serial.write(26);
void read_pulse()
if(!digitalRead(pulsein))
digitalWrite(led, HIGH);
//count++;
//units=watt_factorcount/1000;
if(units<1){}
units--;
dollars=units
5;
EEPROM.write(1,dollars);
while(!digitalRead(pulsein));
digitalWrite(led,LOW);
// delay(2000);
void check_status()
if(dollars>15)
digitalWrite(relay, HIGH);
flag1=0;
flag2=0;
if(dollars<15 && flag1==0)
lcd.setCursor(0,1);
lcd.print("LOW Balance ");
init_sms();
send_data("Energy Meter Balance Alert:");
send_data("Low Balance\n");
Serial.println(dollars);
delay(200);
send_data("Please recharge your energy meter soon.\n Thank you");
send_sms();
message_sent();
flag1=1;
if(dollars<5 && flag2==0)
digitalWrite(relay, LOW);
lcd.clear();
lcd.print("Light Cut Due to");
lcd.setCursor(0,1);
lcd.print("Low Balance");
delay(2000);
lcd.clear();
lcd.print("Please Recharge ");
lcd.setCursor(0,1);
lcd.print("UR Energy Meter ");
init_sms();
send_data("Energy Meter Balance Alert:\nLight cut due to low Balance\nPlease recharge your energy meter soon.\n Thank you");
send_sms();
message_sent();
flag2=1;
void decode_message()
x=0,k=0,temp=0;
while(x<i)
while(str[x]=='#')
x++;
bal="";
while(str[x]!='*')
bal+=str[x++];
x++;
bal+='\0';
void send_confirmation_sms()
int recharge_amount=bal.toInt();
dollars+=recharge_amount;
EEPROM.write(1, dollars);
lcd.clear();
lcd.print("Energy Meter ");
lcd.setCursor(0,1);
lcd.print("Recharged:");
lcd.print(recharge_amount);
init_sms();
send_data("Energy Meter Balance Alert:\nYour energy meter has been recharged Rs:");
send_data(bal);
send_data("Total Balance:");
delay(200);
send_data("Eelctricity Has Been Connected\nThank you");
send_sms();
temp=0;
i=0;
x=0;
k=0;
message_sent();
void message_sent()
lcd.clear();
lcd.print("Message Sent.");
void gsm_init()
lcd.clear();
lcd.print("Finding Module..");
boolean at_flag=1;
while(at_flag)
Serial.println("AT");
while(Serial.available()>0)
at_flag=0;
lcd.clear();
lcd.print("Module Connected..");
lcd.clear();
lcd.print("Disabling ECHO");
boolean echo_flag=1;
while(echo_flag)
Serial.println("ATE0");
echo_flag=0;
lcd.clear();
lcd.print("Echo OFF");
lcd.clear();
lcd.print("Finding Network..");
boolean net_flag=1;
while(net_flag)
Serial.println("AT+CPIN?");
net_flag=0;
lcd.clear();
lcd.print("Network Found..");
lcd.clear();
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool but it's still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if the problem goes away, then turn the antivirus back on. If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to whitelist the appropriate file, folder, or process so it doesn't interfere with compilation.
