Compiling Error when uploading pulseoximeter code example from E health sensor
Hi when I tried to upload the following code into Arduino uno3:
#include <PinChangeInt.h>
#include <eHealth.h>
int cont = 0;
eHealth.initPulsioximeter();
//Attach the inttruptions for using the pulsioximeter.
PCintPort::attachInterrupt(6, readPulsioximeter, RISING);
Serial.print("PRbpm : ");
Serial.print(eHealth.getBPM());
Serial.print(" %SPo2 : ");
Serial.print(eHealth.getOxygenSaturation());
Serial.print("\n");
Serial.println("=============================");
//Include always this code when using the pulsioximeter sensor
void readPulsioximeter(){
cont ++;
if (cont == 50) { //Get only of one 50 measures to reduce the latency
eHealth.readPulsioximeter();
cont = 0;
I got the following compiling error:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
In file included from C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:33:0:
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.h:149:15: error: 'prog_uint8_t' has not been declared
PROGMEM prog_uint8_t *array);
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:41:11: error: 'prog_uint8_t' does not name a type
PROGMEM prog_uint8_t eHealthLogo[] = {
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:109:10: error: 'prog_uint8_t' does not name a type
PROGMEM prog_uint8_t cookingLogo[] = {
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp: In member function 'void eHealthDisplayClass::init()':
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:201:21: error: 'eHealthLogo' was not declared in this scope
image(0,64,128,64,eHealthLogo);
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:209:21: error: 'cookingLogo' was not declared in this scope
image(0,64,128,64,cookingLogo); delay(3000);
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp: At global scope:
C:\Users\Lenovo\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:663:20: error: 'prog_uint8_t' has not been declared
Error compiling.
enabled in File > Preferences.
Could you help me with these?
Thank you.
I had tried to add the following code above the e health.h but it didn’t work:
#ifndef prog_uint8_t
#define prog_uint8_t const uint8_t
#endif
I am using Arduino version 1.6.5
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
