Compiling error with IRremote
Getting the following compiling error when trying to run IRtest from the example library.
Any help would be greatly appreciated.
ArduinoIRremotemaster\IRremote.cpp.o: In function MATCH(int, int)': /IRremoteInt.h:176: multiple definition of MATCH(int, int)’
IRtest.cpp.o:C:\Users\Phil\Documents\Arduino\libraries\ArduinoIRremotemaster/IRremoteInt.h:176: first defined here
ArduinoIRremotemaster\IRremote.cpp.o: In function MATCH_MARK(int, int)': /IRremoteInt.h:177: multiple definition of MATCH_MARK(int, int)’
IRtest.cpp.o:C:\Users\Phil\Documents\Arduino\libraries\ArduinoIRremotemaster/IRremoteInt.h:177: first defined here
ArduinoIRremotemaster\IRremote.cpp.o: In function MATCH_SPACE(int, int)': /IRremoteInt.h:178: multiple definition of MATCH_SPACE(int, int)’
IRtest.cpp.o:C:\Users\Phil\Documents\Arduino\libraries\ArduinoIRremotemaster/IRremoteInt.h:178: first defined here
IRtest code:
  • IRremote: IRtest unittest
  • Version 0.1 July, 2009
  • Copyright 2009 Ken Shirriff
  • http://arcfn.com
  • Note: to run these tests, edit IRremote/IRremote.h to add “#define TEST”
  • You must then recompile the library by removing IRremote.o and restarting
  • the arduino IDE.
#include <IRremote.h>
#include <IRremoteInt.h>
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
// decode_results *results = (decode_results *)v
void dump(decode_results *results) {
int count = results->rawlen;
if (results->decode_type == UNKNOWN) {
Serial.println(“Could not decode message”);
else {
if (results->decode_type == NEC) {
Serial.print("Decoded NEC: ");
else if (results->decode_type == SONY) {
Serial.print("Decoded SONY: “);
else if (results->decode_type == RC5) {
Serial.print(“Decoded RC5: “);
else if (results->decode_type == RC6) {
Serial.print(“Decoded RC6: “);
Serial.print(results->value, HEX);
Serial.print(” (”);
Serial.print(results->bits, DEC);
Serial.println(” bits)”);
Serial.print(“Raw (”);
Serial.print(count, DEC);
Serial.print(”): ");
for (int i = 0; i < count; i++) {
if ((i % 2) == 1) {
Serial.print(results->rawbuf_*USECPERTICK, DEC);_
  • else {*
    Serial.print(-(int)results->rawbuf_USECPERTICK, DEC);_
    _
    }_
    _
    Serial.print(" “);_
    _
    }_
    _
    Serial.println(”");_
    _
    }_
    IRrecv irrecv(0);
    decode_results results;
    class IRsendDummy :
    public IRsend
    _
    {_
    public:
    _
    // For testing, just log the marks/spaces*_
    #define SENDLOG_LEN 128
    * int sendlog[SENDLOG_LEN];
    _
    int sendlogcnt;_
    _
    IRsendDummy() :_
    _
    IRsend() {_
    _
    }_
    _
    void reset() {_
    _
    sendlogcnt = 0;_
    _
    }_
    _
    void mark(int time) {_
    _
    sendlog[sendlogcnt] = time;_
    if (sendlogcnt < SENDLOG_LEN) sendlogcnt++;
    _
    }_
    _
    void space(int time) {_
    _
    sendlog[sendlogcnt] = -time;_
    _
    }_
    _
    // Copies the dummy buf into the interrupt buf*_
    * void useDummyBuf() {*
    * int last = SPACE;*
    * irparams.rcvstate = STATE_STOP;
    _
    irparams.rawlen = 1; // Skip the gap*_
    * for (int i = 0 ; i < sendlogcnt; i++) {*
    _ if (sendlog < 0) {
    * if (last == MARK) {
    // New space*
    irparams.rawbuf[irparams.rawlen++] = (-sendlog - MARK_EXCESS) / USECPERTICK;
    * last = SPACE;
    else {
    // More space*
    irparams.rawbuf[irparams.rawlen - 1] += -sendlog / USECPERTICK;
    else if (sendlog > 0) {
    if (last == SPACE) {
    // New mark*
    irparams.rawbuf[irparams.rawlen++] = (sendlog + MARK_EXCESS) / USECPERTICK;
    * last = MARK;
    else {
    // More mark*
    irparams.rawbuf[irparams.rawlen - 1] += sendlog / USECPERTICK;
    if (irparams.rawlen % 2) {
    irparams.rawlen–; // Remove trailing space*
    IRsendDummy irsenddummy;
    void verify(unsigned long val, int bits, int type) {
    irsenddummy.useDummyBuf();
    irrecv.decode(&results);
    Serial.print(“Testing “);
    Serial.print(val, HEX);_
    if (results.value == val && results.bits == bits && results.decode_type == type) {
    _ Serial.println(”: OK”);
    else {
    Serial.println(": Error");
    dump(&results);
    void testNEC(unsigned long val, int bits) {
    irsenddummy.reset();
    irsenddummy.sendNEC(val, bits);
    verify(val, bits, NEC);
    void testSony(unsigned long val, int bits) {
    irsenddummy.sendSony(val, bits);
    verify(val, bits, SONY);
    void testRC5(unsigned long val, int bits) {
    irsenddummy.sendRC5(val, bits);
    verify(val, bits, RC5);
    void testRC6(unsigned long val, int bits) {
    irsenddummy.sendRC6(val, bits);
    verify(val, bits, RC6);
    void test() {
    Serial.println(“NEC tests”);
    testNEC(0x00000000, 32);
    testNEC(0xffffffff, 32);
    testNEC(0xaaaaaaaa, 32);
    testNEC(0x55555555, 32);
    testNEC(0x12345678, 32);
    Serial.println(“Sony tests”);
    testSony(0xfff, 12);
    testSony(0x000, 12);
    testSony(0xaaa, 12);
    testSony(0x555, 12);
    testSony(0x123, 12);
    Serial.println(“RC5 tests”);
    testRC5(0xfff, 12);
    testRC5(0x000, 12);
    testRC5(0xaaa, 12);
    testRC5(0x555, 12);
    testRC5(0x123, 12);
    Serial.println(“RC6 tests”);
    testRC6(0xfffff, 20);
    testRC6(0x00000, 20);
    testRC6(0xaaaaa, 20);
    testRC6(0x55555, 20);
    testRC6(0x12345, 20);
    test();
    }*_
Could you put some spaces in the code, so it's not bunched up, and in the proper code tags "#"
