Compiling error with Time Library
Hello all, and please help!
I downloaded Time library. But, I have compile error. Here is a code:
 * TimeSerial.pde
 * example code illustrating Time library set through serial port messages.
 * Messages consist of the letter T followed by ten digit time (as seconds since Jan 1 1970)
 * you can send the text on the next line using Serial Monitor to set the clock to noon Jan 1 2010
 T1262347200
 * A Processing example sketch to automatically send the messages is inclided in the download
#include <Time.h>
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
void setup()  {
  setSyncProvider( requestSync);  //set function to call when sync required
  Serial.println("Waiting for sync message");
void loop(){
  if(Serial.available() )
    processSyncMessage();
  if(timeStatus()!= timeNotSet)
    digitalWrite(13,timeStatus() == timeSet); // on if synced, off if needs refresh
    digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void processSyncMessage() {
  // if time sync available from serial port, update time and return true
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      setTime(pctime);   // Sync Arduino clock to the time received on the serial port
time_t requestSync()
  Serial.print(TIME_REQUEST,BYTE);
  return 0; // the time will be sent later in response to serial mesg
and errors:
TimeSerial.cpp: In function 'time_t requestSync()':
TimeSerial.pde:-1: error: 'BYTE' was not declared in this scope
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
First, I change BYTE to byte. After that I have this error:
TimeSerial.pde:-1: error: expected primary-expression before ')' token
Please, where is problem?
Give this a look...
http://arduino.cc/forum/index.php/topic,66054.0.html
If you can't find an answer, report back.
Thanks for not prompt reply.
I have read all the posts, and I have not managed to solve the problem.
I tried that example, "Time" to copy the folder Ekamples - I get the same error.
In one post, I found it necessary to replace BYTE with byte (0). After that there have been other errors:
In file included from D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:53:
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial/WiFlySerial.h:199: error: 'SoftwareSerial' does not name a type
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In constructor 'WiFlySerial::WiFlySerial(byte, byte)':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:329: error: class 'WiFlySerial' does not have any field named 'uart'
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:350: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'int WiFlySerial::ScanForPattern(char*, int, const char*, boolean, long unsigned int, boolean)':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:464: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'boolean WiFlySerial::StartCommandMode(char*, int)':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:549: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:575: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:581: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'boolean WiFlySerial::GetCmdPrompt()':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:622: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'boolean WiFlySerial::SendCommand(char*, char*, char*, int, boolean, long unsigned int, boolean, boolean)':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:695: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'virtual int WiFlySerial::peek()':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:1747: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'virtual size_t WiFlySerial::write(uint8_t)':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:1750: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'virtual int WiFlySerial::read()':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:1760: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'virtual int WiFlySerial::available()':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:1776: error: 'uart' was not declared in this scope
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp: In member function 'virtual void WiFlySerial::flush()':
D:\Downloads\Programs\arduino-1.0.1-windows\arduino-1.0.1\libraries\WiFlySerial\WiFlySerial.cpp:1779: error: 'uart' was not declared in this scope
I really do not know what to do?
Which Time library did you download (IOW, where did you get it)? This one:
http://www.arduino.cc/playground/Code/Time
works fine for me with Arduino 1.0.1.
What does "Compiling error with Time Library" have to do with
You are downloading libraries and putting them in the wrong place. YOU are shooting yourself in the foot.
You should have a libraries folder in your sketch folder. if not, create one. THAT is where you download libraries to.
Thanks, but ...
How do I create a folder librarj when every time you start the Arduino to create a new folder in
C:\Users\Pedja\AppData\Local\Temp?
  1. start: C:\Users\Pedja\AppData\Local\Temp\untitled8972537458565446593.tmp\sketch_sep23a
  2. start: C:\Users\Pedja\AppData\Local\Temp\untitled1196531651570556719.tmp\sketch_sep23a
I'm sorry, but I do not understand anything! Can you give me an example? In the following pictures you can see where the folder with arduino:
The library folder goes into your personal sketch folder.
You can pretend those temp folders don't exist. They're managed by the IDE at build time.
