I don't get it. This seems like such an easy fix but I can't spot the compiling problem. The code below.
TLC5940 demonstration sketch
John Boxall - http://tronixstuff.com/partreviews - 17 July 2010
uses code and library by Alex Leone
<acleone ~AT~ gmail.com>, 2009-02-03
TLC5940 library falls under GPLv3 license - see http://www.gnu.org/licenses/
///////////////////////////////// Warning //////////////////////////////////////////////////
////////// You need external power for your Arduino board - USB is not enough!!/////////////
///////////// TLC5940 + 16 LEDs draw over 300 mA at full brightness! ///////////////////////
#include <IRremote.h>
#include "Tlc5940.h"
#define PIN_IR 2 //output to IR transmitter
#define PIN_IR_DETECT 4 //tied to output of IR detector
#define PIN_IR_STATUS 6 //IR LED indicator
#define PIN_PIR_DETECT 5 //tied to output of PIR detector
#define PIN_PIR_STATUS 7 //PIR LED indicator
#define LDR_PIN 2;
boolean IR_Status;
boolean PIR_Status;
int LDR_Value;
boolean Night_Status;
/* Call Tlc.init() to setup the tlc.
You can optionally pass an initial PWM value (0 - 4095) for all channels.*/
Tlc.init();
void knightrider()
/* This loop will create a Knight Rider-like effect if you have LEDs plugged
into all the TLC outputs. NUM_TLCS is defined in "tlc_config.h" in the
library folder. After editing tlc_config.h for your setup, delete the
Tlc5940.o file to save the changes. */
int direction = 1;
for (int channel = 0; channel < 1 * 10; channel += direction) {
/* Tlc.clear() sets all the grayscale values to zero, but does not send
them to the TLCs. To actually send the data, call Tlc.update() */
Tlc.clear();
/* Tlc.set(channel (0-15), value (0-4095)) sets the grayscale value for
one channel (15 is OUT15 on the first TLC, if multiple TLCs are daisy-
chained, then channel = 16 would be OUT0 of the second TLC, etc.).
value goes from off (0) to always on (4095).
Like Tlc.clear(), this function only sets up the data, Tlc.update()
will send the data. */
if (channel == 0) {
direction = 1;
else {
Tlc.set(channel - 1, 1000);
Tlc.set(channel, 4095);
if (channel != 1 * 10 - 1) {
Tlc.set(channel + 1, 1000);
else {
direction = -1;
/* Tlc.update() sends the data to the TLCs. This is when the LEDs will
actually change. */
Tlc.update();
delay(50);
void breathe(int qq) // qq is number of times to breathe :)
// displays all LEDs and alters the brightness
Tlc.clear();
for (int q=0; q<qq; q++) //File:
//Unsaved Document 1 Page 2 of 2
for (int p=0; p<4096; p+=10) // increase brightness
for (int l=0; l<10; l++)
Tlc.set(l, p);
Tlc.update();
delay(5);
for (int p=4095; p>=0; p-=10) // decrease brightness
Tlc.set(l, p);
Tlc.update();
delay(5);
void randomled(int m)
// displays random LEDs for m times
randomSeed(analogRead(0));
for (int qq=0; qq<m; qq++)
Tlc.clear();
Tlc.set(random(10), 4095);
Tlc.update();
delay(200);
void loop(){
IR_Status = digitalRead(PIN_IR_DETECT);
LDR_Value = analogRead(LDR_PIN);
PIR_Status = digitalRead(PIN_PIR_DETECT);
if (LDR_Value >700){
Night_Status = false;
Serial.print ("It is daytime. No sensors monitored. ");
Serial.print ("LDR Value = ");
Serial.println(LDR_Value);
else{
Serial.println("It is nightime. Sensors are monitored. ");
if (IR_Status){
digitalWrite(PIN_IR_STATUS,HIGH);
Serial.println(" IR BEAM BROKEN ");
else{
digitalWrite(PIN_IR_STATUS,LOW);
if (PIR_Status){
digitalWrite(PIN_PIR_STATUS,HIGH);
Serial.println(" PIR DETECTION");
else{
digitalWrite(PIN_PIR_STATUS,LOW);
if(Night_Status == false &&(IR_Status || PIR_Status))
randomled(100);
breathe(3);
knightrider();
If I comment out the line:
It'll compiles so it's gotta be a problem solely with that line.
The error is:
TLC5940_10leds_demo.cpp: In function 'void loop()':
TLC5940_10leds_demo:114: error: expected )' before ';' token TLC5940_10leds_demo:114: error: expected primary-expression before ')' token TLC5940_10leds_demo:114: error: expected ;' before ')' token
I copied that line from another sketch where it compiles without a problem. I just can't see it. - Scotty
