Hi, I use sample code and get error:
d:/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr6/crtm2560.o: In function __vector_default':** **(.vectors+0xdc): relocation truncated to fit: R_AVR_13_PCREL against symbol
__vector_55' defined in .text.__vector_55 section in core.a(HardwareSerial.cpp.o)
sample code is:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); //pin2 Rx, pin3 Tx
Serial.println("Serial number will be displayed here if a card is detected by the module:\n");
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
mySerial.write(0x02); //Send the command to RFID, please refer to RFID manual
void loop() // run over and over
if (mySerial.available())
Serial.print(mySerial.read(),HEX); //Display the Serial Number in HEX
if (Serial.available())
mySerial.write(Serial.read());
can anyone help to fix this problem?
