I am doing an incline (cable car) animation for my model railroad where a car is taken up and down the mountain continuously using a continuous servo and break beam IR sensors. I’ve got most of the bugs out but can’t figure this out. Error messages are at the bottom of the sketch. Appreciate any help for this newcomer - my first project. Thanks
/* Servo modified to run continuously; On startup, it looks for the
location of the car and starts it upward if at the bottom
and downward if at the top or in between. It then Stops when either top or bottom
IR sensor beam is broken; waits a period of time and starts in opposite
direction */
#include <Servo.h>
Servo motor;
int IRTOP = 4; // IR sensors hooked up to pins 4 and 5
int IRBOT = 5;
motor.attach(9);
pinMode (IRTOP, INPUT_PULLUP);
pinMode (IRBOT, INPUT_PULLUP);
int topState = 0; // state of ir sensor high if unbroken
int botState = 0;
// find location of car and get it started
topState = digitalRead (IRTOP);
botState = digitalRead (IRBOT);
if (topState == HIGH && botState == LOW) // car is at bottom
motor.write (95); // start car to go up
motor.write (85); // car is in middle or top, start to go down
if (topState == LOW || botState = LOW); // stop the car
motor.write (90);
delay (15000);
if (topState == LOW); //car is ready to go down
motor.write (85);
motor.write (95); // car is at bottom and ready to go up
Arduino: 1.7.3 (Windows 8.1), Board: "Arduino Uno"
Ver1_Servo_IR_sensors.ino: In function 'void loop()':
Ver1_Servo_IR_sensors.ino:34:3: error: 'topState' was not declared in this scope
Ver1_Servo_IR_sensors.ino:34:27: error: 'IRTOP' was not declared in this scope
Ver1_Servo_IR_sensors.ino:35:3: error: 'botState' was not declared in this scope
Ver1_Servo_IR_sensors.ino:35:27: error: 'IRBOT' was not declared in this scope
Error compiling.
enabled in File > Preferences.
