Good Morning/Afternoon all. I have been using the Arduino IDE for some time but after trying to connect to Industrial 101 board I am getting a compiling error that I cannot figure out. I do not recognize the file path listed in the compiler however I do not even know if that matters. Take a look below if you will please and let me know where to begin to look.
Arduino: 1.8.5 (Mac OS X), Board: “Arduino/Genuino Uno”
/private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/hardware -hardware /Users/cliffsharp/Library/Arduino15/packages -tools /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/cliffsharp/Library/Arduino15/packages -built-in-libraries /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/libraries -libraries /Users/cliffsharp/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path /var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_build_226266 -warnings=all -build-cache /var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_cache_185406 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.1.1 -prefs=runtime.tools.avr-gcc.path=/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9 -verbose /var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/untitled1580392454.tmp/sketch_apr09a/sketch_apr09a.ino
/private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/hardware -hardware /Users/cliffsharp/Library/Arduino15/packages -tools /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/cliffsharp/Library/Arduino15/packages -built-in-libraries /private/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/AppTranslocation/CEFF847B-5EE4-4028-8A9C-DA601FBA0570/d/Arduino.app/Contents/Java/libraries -libraries /Users/cliffsharp/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path /var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_build_226266 -warnings=all -build-cache /var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_cache_185406 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.1.1 -prefs=runtime.tools.avr-gcc.path=/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9 -verbose /var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/untitled1580392454.tmp/sketch_apr09a/sketch_apr09a.ino
Using board ‘uno’ from platform in folder: /Users/cliffsharp/Library/Arduino15/packages/arduino/hardware/avr/1.6.21
Using core ‘arduino’ from platform in folder: /Users/cliffsharp/Library/Arduino15/packages/arduino/hardware/avr/1.6.21
Detecting libraries used…
“/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-I/Users/cliffsharp/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino” “-I/Users/cliffsharp/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/variants/standard” “/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_build_226266/sketch/sketch_apr09a.ino.cpp” -o “/dev/null”
Generating function prototypes…
“/Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-I/Users/cliffsharp/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino” “-I/Users/cliffsharp/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/variants/standard” “/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_build_226266/sketch/sketch_apr09a.ino.cpp” -o “/var/folders/gv/hz3r9n6j4nlgm0rgk0q2cdvr0000gn/T/arduino_build_226266/preproc/ctags_target_for_gcc_minus_e.cpp”
fork/exec /Users/cliffsharp/Library/Arduino15/packages/arduino/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++: no such file or directory
Error compiling for board Arduino/Genuino Uno.
