Compiling Error
Hi guys,
I previously posted on here about 2 weeks ago about a code getting written up and I managed to write my own code up.
I was wondering if anyone can help find the error in my code as I cannot and it will not port to my adruino nano board.
Thanks!
Cody_Beckley_arm_car.ino (14.6 KB)
You're more likely to get help if you:
  • Put the code in the post- especially for those on their mobiles
  • Put the complete compile error in the post too
Did you look at the size? OP can't put it in the post.
sterretje:
Then the OP should pare it down to the minimum complete sketch which exhibits the compile errors.
And who knows, in doing so there may be an Ah, Bisto moment where the issue reveals itself.
  Blynk.run();
/////////////////////////////// . YOU FORGOT A '}' HERE
  //Defines
#define mSpeedFast 90
#define mSpeedMedium 70
YOU HAVE TWO setup() FUNCTION (Lines 17 and 64).
Did you write your code in stages?
Getting each stage to compile and work before adding the next?
What model Arduino is it coded for?
If so then you will know what you added to cause the compile fault.
Tom... :slight_smile:
