Compiling errors while trying to implement I2C multiplexer
I am using the TCA9548A I2C multiplexer with two of the same sensor (MAG3110). I am following this example code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
#define TCAADDR 0x70
/* Assign a unique ID to this sensor at the same time */
Adafruit_HMC5883_Unified mag1 = Adafruit_HMC5883_Unified(1);
Adafruit_HMC5883_Unified mag2 = Adafruit_HMC5883_Unified(2);
void displaySensorDetails(Adafruit_HMC5883_Unified *mag)
  sensor_t sensor;
  mag->getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" uT");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" uT");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" uT");
  Serial.println("");
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
void setup(void)
  Serial.println("HMC5883 Magnetometer Test"); Serial.println("");
  /* Initialise the 1st sensor */
  tcaselect(2);
  if(!mag1.begin())
    /* There was a problem detecting the HMC5883 ... check your connections */
    Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
    while(1);
  /* Initialise the 2nd sensor */
  tcaselect(6);
  if(!mag2.begin())
    while(1);
  /* Display some basic information on this sensor */
  tcaselect(2);
  displaySensorDetails(&mag1);
  tcaselect(6);
  displaySensorDetails(&mag2);
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  tcaselect(2);
  mag1.getEvent(&event);
  /* Display the results (magnetic vector values are in micro-Tesla (uT)) */
  Serial.print("Sensor #1 - ");
  Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print("  ");
  Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print("  ");
  Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print("  ");Serial.println("uT");
  tcaselect(6);
  mag2.getEvent(&event);
  Serial.print("Sensor #2 - ");
But, I keep getting errors. Mainly, my code doesn't like that I'm putting an argument in MAG3110() and mag.initialize(), and so on. I'm not sure why it's a problem here but it's fine with the example code. Below is my code.
#include <SparkFun_MAG3110.h>
MAG3110 mag = MAG3110(0); //Instantiate MAG3110
MAG3110 mag1 = MAG3110(1);
  if (i > 7) return;
  Wire.beginTransmission(0x70);
  Wire.write(1 << i);
  mag.initialize(0); //Initializes the mag sensor
  mag.start(0);    //Puts the sensor in active mode
  mag1.initialize(1);
  mag1.start(1);
  int x, y, z;
  //Only read data when it's ready
 tcaselect(0);
  if(mag.dataReady(0)) {
    //Read the data
    mag.readMag(&x, &y, &z);
    Serial.print(x);
    Serial.print(", Y: ");
    Serial.print(y);
    Serial.print(", Z: ");
    Serial.println(z);
    Serial.println("--------");
  tcaselect(1);
      if(mag1.dataReady(1)) {
    //Read the data
    mag1.readMag(&x, &y, &z);
    Serial.print(x);
    Serial.print(y);
    Serial.println(z);
    delay(200);
Full error would have been nice :wink:
But uhm, maybe include the SparkFun MAG3110 library? :wink:
The library is included. The code I am using is the second code, I am just referencing the top code to set up the multiplexer.
Here are the error messages:
sketch_jul18d:4: error: no matching function for call to 'MAG3110::MAG3110(int)'
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:4:24: note: candidates are:
In file included from C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:1:0:
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:124:3: note: MAG3110::MAG3110()
   MAG3110();
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:124:3: note:   candidate expects 0 arguments, 1 provided
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:121:7: note: constexpr MAG3110::MAG3110(const MAG3110&)
 class MAG3110
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:121:7: note:   no known conversion for argument 1 from 'int' to 'const MAG3110&'
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:121:7: note: constexpr MAG3110::MAG3110(MAG3110&&)
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:121:7: note:   no known conversion for argument 1 from 'int' to 'MAG3110&&'
sketch_jul18d:5: error: no matching function for call to 'MAG3110::MAG3110(int)'
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:5:25: note: candidates are:
   MAG3110();
 class MAG3110
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino: In function 'void setup()':
sketch_jul18d:18: error: no matching function for call to 'MAG3110::initialize(int)'
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:18:19: note: candidate is:
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:126:8: note: void MAG3110::initialize()
   void initialize();
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:126:8: note:   candidate expects 0 arguments, 1 provided
sketch_jul18d:19: error: no matching function for call to 'MAG3110::start(int)'
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:19:14: note: candidate is:
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:145:8: note: void MAG3110::start()
   void start();
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:145:8: note:   candidate expects 0 arguments, 1 provided
sketch_jul18d:20: error: no matching function for call to 'MAG3110::initialize(int)'
   mag1.initialize(1);
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:20:20: note: candidate is:
   void initialize();
sketch_jul18d:21: error: no matching function for call to 'MAG3110::start(int)'
   mag1.start(1);
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:21:15: note: candidate is:
   void start();
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino: In function 'void loop()':
sketch_jul18d:29: error: no matching function for call to 'MAG3110::dataReady(int)'
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:29:21: note: candidate is:
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:132:8: note: bool MAG3110::dataReady()
   bool dataReady();
C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master\src/SparkFun_MAG3110.h:132:8: note:   candidate expects 0 arguments, 1 provided
sketch_jul18d:43: error: no matching function for call to 'MAG3110::dataReady(int)'
C:\Users\slb0494\Documents\Arduino\BS\sketch_jul18d\sketch_jul18d.ino:43:26: note: candidate is:
   bool dataReady();
sketch_jul18d:57: error: expected '}' at end of input
Using library SparkFun_MAG3110_Breakout_Board_Arduino_Library-master at version 1.0.0 in folder: C:\Users\slb0494\Documents\Arduino\libraries\SparkFun_MAG3110_Breakout_Board_Arduino_Library-master
Using library Wire at version 1.0 in folder: C:\Users\slb0494\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\Wire
exit status 1
So you have separate code for the sensors and the multiplexer? How is that going to help you?
Delta_G:
What are the 0 and 1 supposed to be? The compiler says that constructor doesn't take any arguments. It has no code to do anything with the 0 or the 1. So what are intending to happen with them?
I don't know entirely what their purpose is, I assumed it was just to differentiate between the two sensors. I was essentially just trying to follow exactly what they did in the example code(1st code I posted) and impliment that into my code(2nd code I posted), but I really don't know what a lot of it actually means.
Yes, it is, but I assumed that the multiplexer portion of the code would be applicable regardless of the library being used, because it is an entirely different device. I have scoured the internet and have been unable to find any examples utilizing the exact sensor I'm using. Implementing the multiplexer should be the same regardless, though (as long as the sensor uses I2C communication). Can you offer any help on coding for the multiplexer itself?
Multiplexer is separate device and needs separate control. But if you want to control your sensor you can't just mix and match code and libraries...
And your sensor and sensor library no nothing about the I2C multiplexer. That's all up to you :slight_smile:
So grab the library you like for the sensor. Make the code for the I2C multiplexer (or grab a library if available) and try again :slight_smile:
septillion:
Making the code for the multiplexer is what I'm struggling with, I'm aware that it has nothing to do with the sensor library. The code and library I have for my sensor work fine if I'm only trying to use one sensor, but I'm struggling with the multiplexer implementation for multiple sensors.
Alright, take a step back. Then take little steps. Only continue if it was successful
  1. Connect the sensor to the Arduino
  2. Read it with the library you want
  3. Connect the multiplexer only
  4. Do a I2C scan, can you read it's address?
  5. Connect a single sensor to the multiplexer
  6. Try to make code to set the multiplxer to the pin of that single sensor (hint, make functions)
  7. try to read read the sensor with that same library as in 2 with that code for the multiplexer added
  8. Figure out how to use that library for multiple sensors. Highly depends on the library :slight_smile:
If you're stuck tell us where, show us the code, tell us which library you use, what you expect etc.
