Uno Rev 3.
I have gotten a step further (I think...)
I downloaded the library linked to this post: https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
That had a i2c example script in it:
// Created by Francisco Malpartida on 1/1/12.
// Copyright 2011 - Under creative commons license:
// Attribution-NonCommercial-ShareAlike CC BY-NC-SA
// This software is furnished "as is", without technical support, and with no
// warranty, express or implied, as to its usefulness for any purpose.
// Thread Safe: No
// Extendable: Yes
// @file i2CLCDextraIO.pde
// Temperature logging to demonstrate the I2CLCDextraIO library.
// @brief This application is a demostration file for the I2CLCDextraIO library
// that reads a temperature from the internal ATMEGA328p temperature sensor
// and displays it on the LCD. The application also demonstrates some of the
// methods of the library, such as loading custom characters to the LCD,
// moving around the LCD, and writing to it.
// @author F. Malpartida
#include <Wire.h>
#include <LCD.h>
#define _LCD_I2C_
#ifdef _LCD_I2C_
#endif
#ifdef _LCD_4BIT_
#include <LiquidCrystal.h>
#endif
@defined CHAR_WIDTH
@abstract Character witdth of the display, expressed in pixeles per character.
#define CHAR_WIDTH 5
@defined BACKLIGHT_PIN
@abstract LCD backlight pin definition.
@discussion AVR pin used for the backlight illumintation of the LCD.
#define BACKLIGHT_PIN 7
@defined TEMP_CAL_OFFSET
@abstract Temperature calibration offset.
@discussion This is the offset value that has to be modified to get a
correct temperature reading from the internal temperature sensor
of your AVR.
#define TEMP_CAL_OFFSET 334
@defined FILTER_ALP
@abstract Low pass filter alpha value
@discussion This value defines how much does the current reading, influences
the over all value. The smaller, the less influence the current
reading has over the overall result.
#define FILTER_ALP 0.1
extern unsigned int __bss_end;
extern unsigned int __heap_start;
extern void *__brkval;
#ifdef _LCD_I2C_
LiquidCrystal_I2C lcd(0x38); // set the LCD address to 0x20 for a 16 chars and 2 line display
#endif
#ifdef _LCD_4BIT_
LiquidCrystal lcd(12, 11, 5, 4, 3, 2, BACKLIGHT_PIN, POSITIVE);
#endif
const int CONTRAST_PIN = 9;
const int CONTRAST = 65;
LCD *myLCD = &lcd;
static double tempFilter;
@const charBitmap
@abstract Define Character bitmap for the bargraph.
@discussion Defines a character bitmap to represent a bargraph on a text
display. The bitmap goes from a blank character to full black.
const uint8_t charBitmap[][8] = {
{ 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 },
{ 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x0 },
{ 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x0 },
{ 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x1C, 0x0 },
{ 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x0 },
{ 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x0 },
{ 0xe, 0x11, 0x11, 0x11, 0xe, 0, 0, 0 },
{ 0x6, 0x9, 0x9, 0x6, 0x0, 0, 0, 0}
@function
@abstract Return available RAM memory
@discussion This routine returns the ammount of RAM memory available after
initialising the C runtime.
@param
@result Free RAM available.
static int freeMemory()
int free_memory;
if((int)__brkval == 0)
free_memory = ((int)&free_memory) - ((int)&__bss_end);
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
@function
@abstract Returns AVR328p internal temperature
@discussion Configures the ADC MUX for the temperature ADC channel and
waits for conversion and returns the value of the ADC module
@result The internal temperature reading - in degrees C
static int readTemperature()
ADMUX = 0xC8; // activate interal temperature sensor,
// using 1.1V ref. voltage
ADCSRA |= _BV(ADSC); // start the conversion
while (bit_is_set(ADCSRA, ADSC)); // ADSC is cleared when the conversion
// finishes
// combine bytes & correct for temperature offset (approximate)
return ( (ADCL | (ADCH << 8)) - TEMP_CAL_OFFSET);
@function
@abstract Braws a bargraph onto the display representing the value passed.
@discussion Draws a bargraph on the specified row using barLength characters.
@param value[in] Value to represent in the bargraph
@param row[in] Row of the LCD where to display the bargraph. Range (0, 1)
for this display.
@param barlength[in] Length of the bar, expressed in display characters.
@param start[in] Start bar character
@param end [in] End bar character
@result None
static void drawBars ( int value, uint8_t row, uint8_t barLength, char start,
char end )
int numBars;
// Set initial titles on the display
myLCD->setCursor (0, row);
myLCD->print (start);
// Calculate the size of the bar
value = map ( value, -30, 50, 0, ( barLength ) * CHAR_WIDTH );
numBars = value / CHAR_WIDTH;
// Limit the size of the bargraph to barLength
if ( numBars > barLength )
numBars = barLength;
myLCD->setCursor ( 1, row );
// Draw the bars
while ( numBars-- )
myLCD->print ( char( 5 ) );
// Draw the fractions
numBars = value % CHAR_WIDTH;
myLCD->print ( char(numBars) );
myLCD->setCursor (barLength + 1, row);
myLCD->print (end);
void setup ()
int i;
int charBitmapSize = (sizeof(charBitmap ) / sizeof (charBitmap[0]));
Serial.begin ( 57600 );
analogReference ( INTERNAL );
#ifdef _LCD_4BIT_
pinMode(CONTRAST_PIN, OUTPUT);
lcd.backlight();
digitalWrite(BACKLIGHT_PIN, HIGH);
analogWrite (CONTRAST_PIN, CONTRAST);
#else
pinMode ( BACKLIGHT_PIN, OUTPUT );
#endif
myLCD->begin ( 16, 2 );
// Load custom character set into CGRAM
for ( i = 0; i < charBitmapSize; i++ )
myLCD->createChar ( i, (uint8_t *)charBitmap[i] );
Serial.println ( freeMemory () );
myLCD->clear ();
myLCD->print ("Temp:");
tempFilter = readTemperature (); // Initialise the temperature Filter
void loop ()
int temp;
temp = readTemperature();
tempFilter = ( FILTER_ALP * temp) + (( 1.0 - FILTER_ALP ) * tempFilter);
myLCD->setCursor ( 8, 0 );
myLCD->print (" ");
myLCD->print ( tempFilter, 1 );
myLCD->setCursor ( 12, 0 );
myLCD->print ( "\x07" );
myLCD->print ("C");
drawBars ( tempFilter, 1, 14, '-', '+' );
delay (200);
That did compile and I could upload it to the arduino, but its not displaying as it should. I know that it needs some inputs from a temperature sensor, but no matter what, it should display some kind of text, which it doesnt. It moves the cursor, fades, blinks and all in all looks wrongly pinned out. But its the best ive done so far.
