Compiling errors
Please I need your help I want to finish my project but just the code is remaining .when I try to compile the code it gives me one error or another,I don’t understand what am meant to correct am using Arduino/ genuino uno board. And also IRremote library.if you could help me cross-check for my errors.here is d code below
#include <IRremote.h>
#include <avr/interrupt.h>
const int RECV_PIN=5;
#define  code1 16718055 //button 2
#define  code2 16730805//button 8
#define  code3 16716015 //button 4
#define  code4 16734885 //button 6
#define  code5 16726215 //button 5
  IRrecv irrecv(RECV_PIN);
  decode_results results;
  irrecv.enableIRIn();
  pinmode (12,output);
  pinmode (11,output);
  pinmode (10,output);
  pinmode (9,output);
  if irrecv.decode (&results)
  unsigned int value=results.value;
  switch [value]{
  case code1;
  digitalwrite(12,HIGH);
  digitalwrite(11,LOW);
  digitalwrite(10,LOW);
  digitalwrite(9,HIGH);
  case code2;
  digitalwrite(12,LOW);
  digitalwrite(11,HIGH);
  digitalwrite(10,HIGH);
  digitalwrite(9,LOW);
  case code3;
  case code4;
  case code5;
  irrecv.resume()
    case code1;
Cases should end with a colon not a semicolon
 pinmode (12, output);
pinmode() is not the same as pinMode()
output is not the same as OUTPUT
Check the syntax of the if statement
  switch [value]
The [ and ] should be ( and )
      digitalwrite(12, HIGH);
digitalwrite is not the same as digitalWrite
  irrecv.resume()
Missing semicolon
  switch (value)
value is declared in the code block of the preceding if command and is, therefore, out of scope here
Apart from those errors the code looks OK but I did not look at its logic
To save time, you could've simply posted the errors you saw.
UKheliBob
What is the syntax of IF statement
And for the last error you talked about I don't understand could u please expanciate.
if/else statement courtesy of Mr Google
Which one ? I added several over a short period of time
UKHeliBob:
Dollars to donuts, it's the scope one....
  switch (value){
    //snip - lots of bad code as discussed elsewhere
If what you meant was:
  if irrecv.decode (&results) {
  switch (value){
when you try to switch on value, it will complain that value is undefined, because it's no longer in scope, as you declared it inside a block, but you are no longer in said block.
I suspect that what you wanted, though was something like this - because if you haven't set value, the switch/case statement is meaningless, and you probably don't want to run it at all.
  if (irrecv.decode(&results)) {
  switch (value){
Others have described the many other issues with your code.
But another error came up it says- "value" not declared in this scope.
What do I do in this .
  switch [value]{
switch [value] Oops
Hi guys thank you my problem as been solved the last error was this;
switch [value]{
Instead of;
switch (results.value){
The value member of the struct that results is an instance of is NOT an unsigned int. Use the proper type to uselessly store a copy of the value in results.value.
