I have been trying every code on the net to get a servo to move with an Uno and have been unsuccessful in every attempt. I even tried to use the example code from the examples in 1.0.1
This gives me a
Sweep:7: error: 'Servo' does not name a type
Sweep.cpp: In function 'void setup()':
Sweep:14: error: 'myservo' was not declared in this scope
Sweep.cpp: In function 'void loop()':
Sweep:22: error: 'myservo' was not declared in this scope
Sweep:27: error: 'myservo' was not declared in this scope
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Why in the world would you put a code in the examples of the Arduino program if they don't work?
