We have printed a hand designed by Open Bionics and are trying to control it using an Arduino Mega. https://www.openbionics.com/downloads/ shows the firmware for their Almond control board using Artichoke firmware. I can open the artichoke firmware in the Arduino IDE, but cannot compile it successfully. I get an error, “‘MYSERIAL’ was not declared in this scope”. MYSERIAL was called in several of the libraries that were included with the code. I am including a few- please just let me know if I should post more of them!
I am working under the assumption that the original posted code compiled and that I have to change something due to trying to use this code on the Mega. But I have not been successful in finding what I might have to change to make this work. I would appreciate any help!
Code for Artichoke:
/* Open Bionics - Artichoke
* Author - Olly McBride
* Date - December 2015
* This work is licensed under the Creative Commons Attribution-ShareAlike 4.0 International License.
* To view a copy of this license, visit http://creativecommons.org/licenses/by-sa/4.0/.
* Website - http://www.openbionics.com/
* GitHub - https://github.com/Open-Bionics
* Email - ollymcbride@openbionics.com
* OpenBionics_Artichoke.ino
#include <FingerLib.h> // This library can be downloaded from https://github.com/Open-Bionics
#include <Wire.h>
#include <EEPROM.h>
#include "Globals.h"
#include "GripControl.h"
#include "CircleBuff.h"
#include "Demo.h"
#include "EMGControl.h"
#include "MotorControl.h"
#include "PinManagement.h"
#include "SerialControl.h"
#include "TimerManagement.h"
#include "Utils.h"
#ifdef USE_I2C_ADC
#include <I2C_ADC.h> // This library can be downloaded from https://github.com/Open-Bionics
#endif
#ifdef HANDLE_EN
#include "Wiichuck.h" // Nunchuck library, written by jnw.walker@gmail.com
#include "HANDle.h"
#endif
* Open Bionics - Artichoke Release Notes
* Version | Date | Notes
* V1.0.0 | 08/01/16 | Initial release for Ada hand and Almond boards using Atmega 2560
* V1.0.1 | 03/02/16 | Modified formatting and cleaned up
* V1.1.0 | 31/03/16 | Added research and HANDle mode. Fixed motorEn and muscle graph
* V1.1.1 | 17/05/16 | Increased PWM timer freq to prevent hum and implemented customDelay() instead of delay()
* V1.2.0 | 22/08/16 | Re-written EMG control (now allows both 1 & 2 channel control)
* Artichoke Description
* - Simple hand control software designed to run on the Open Bionics Almond hand controller
* - Uses FingerLib.h for low level finger control, which allows fingers to be treated as servos
* - Can be controlled via the following methods:
* - Serial control (baud 38400)
* - Muscle control (EMG)
* - HANDle control (Nunchuck)
* - Uses either inbuilt ADC or external I2C ADC for muscle sensing and hand control
* - Enter '?' to view available serial commands
// MYSERIAL.begin(38400); // start serial
#if defined(USE_I2C_ADC) || defined(HANDLE_EN)
Wire.begin(); // if using I2C for I2C_ADC or for HANDle control, initialise I2C
#endif
timerSetup(); // start timer interrupts
setDefaults(); // initialise serialCmd.buffs, finger positions and muscle control, read EEPROM presets
IOconfig(); // config finger pins, initialise port expander
startUpMessages(); // print welcome message, current hand configuration/settings
if (advancedSettings.muscleCtrlFlag > 0) // muscle/EMG control
runEMG();
if (demoFlag) // demo mode
demoMode();
// if researchFlag == 1, and no other command is recognised, use CSV string as target motor positions
if (advancedSettings.researchFlag == 1) // if 'A10'
researchMode_CSV_TX();
#ifdef HANDLE_EN
if (advancedSettings.HANDle_en) // HANDle (Nunchuck) control
HANDleMain();
#endif
Globals.h (5.27 KB)
Globals.cpp (932 Bytes)
SerialControl.cpp (19.3 KB)
SerialControl.h (2.23 KB)
