I bought a mouse with the PAN3101 chip. I connected the mouse to the Arduino as shown on the site.
I downloaded the file and I saved it in C: \ Users \ Labs \ Documents \ Arduino \ libraries.
Following the instructions I opened the example Coordinates by File/Sketchbook/Libraries/Optimouse-20093001/Optimouse/Coordinates.
As soon as I open this I get this error message on the default file:
"Coordinates.pde" contains unrecognized characters.If this code was created with an older version of Processing, you may need to use Tools -> Fix Encoding & Reload to updatethe sketch to use UTF-8 encoding. If not, you may need todelete the bad characters to get rid of this warning.
I click on "Verify" (program coordinates) and I get this error message:
Coordinates.pde: 16:21: fatal error: PAN3101.h: No such file or directory
compilation terminated.
And for some reason my IDE throws a fit when I try to use it to make the changes... reports that something is Read-Only and except for the folders none of it is read only.
I made the changes to more than one header file in Wordpad and then it compiles.
I haven't had this much trouble with library example before, it's like there's locks or hidden screws.
I added the new library (Do not unzip the downloaded library, leave it as is) directly from the downloaded folder.
Sketch / import library / add library
Then directly from the folder unzipp I modified the two files optimous.h/pan3101.h removing # include "Wprogram.h" and putting # include <Arduino.h>.
I followed the demands for saving two files and replace them in the folder (created automatically by arduinoIDE after ADDlibrary) C: \ Users \ Labs \ Documents \ Arduino \ libraries \ OptiMouse.
I opened the File / sketchbook / libraries / optimouse / coordinates.
