cOMPILING PROBLEM Solved
I stripped out all the loops etc to find the problem.
/* TDS MEASUREMENT
 #define C+ 0  //digital pin for cap
 #define C- 1  //digital pin for cap
 #define ec 2  //digital pin for cap
pinMode(ec,INPUT);    // High impedence
pinMode(C+,OUTPUT);
digitalWrite(C+, HIGH);                 //1
pinMode(C-,OUTPUT);
digitalWrite(C-, LOW);  // Wait for capacitor to charge.
pinMode(C+,INPUT);
pinMode(ec, OUTPUT);                  //2
digitalWrite(ec, LOW);
// Measure discharge time here
pinMode(C+, OUTPUT);
digitalWrite(C+, HIGH);                 //4  Discharge capacitor
digitalWrite(C-, HIGH);
digitalWrite(C+, LOW);                                  //5 Recharge cap wih reverse polarity
pinMode(C+, INPUT);
pinMode(ec, OUTPUT);                  //6
digitalWrite(ec, HIGH);
//Measure discharge time here
pinMode(ec, INPUT);
//Temp compensation here
I get this on the last line.
expected primary-expression before ',' token
What am i doing wrong ? I am a fairly inexperienced with C.
You can't use + and - symbols in a variable name. The reason is obvious when you consider an expression like va-vb+vc.
Change your #defines. The compiler thinks the '+' and '-' are operators and not part of the identifier.
#define CPLUS 0    //digital pin for cap
#define CMINUS 1   //digital pin for cap
Edit: Make sure your comments convey accurate information
Thank you both
