compiling problem
hey arduino'rs
im new here and my first compilation stuck in a stupid error msg, header files and ino file are in the same directory i checked the name spelling it is correct but it still saying no such a file or directory however im calling a wire.h in the code but this file is not in the directory and i can't find it.
I'll appreciate any help
thank you
Please post your code here and follow the advice in read this before posting a programming question
Thank u guys
i suppose to have the Liquid_CrystalLcd library under the arduino program fiels not my code file
this is what happen when u move from IDE to another one
Does that mean that you have solved your problem, or do you still need some advice?
If you put user contributed libraries in the libraries folder of your sketches folder then they will still be available if you upgrade to a later version of the IDE or have more than one version installed.
