Hoi,
Als ik een werkend programma kopieer in een nieuwe sketch en dan tracht die sketch op te laden
krijg is steeds foutboodschappen, iemand een idee hoe dit kan komen ?
hieronder een voorbeeld van een programma dat ik kopieer en dan de error berichten
de foutboodschap heronder:
Arduino: 1.6.12 (Windows XP), Board: “Arduino/Genuino Uno”
collect2.exe: error: ld returned 5 exit status
Multiple libraries were found for “Dhcp.h”
Used: C:\Program Files\Arduino\libraries\Ethernet2-master
Not used: C:\Program Files\Arduino\libraries\Ethernet
Using library idDHT11-master in folder: C:\Program Files\Arduino\libraries\idDHT11-master (legacy)
Using library Ethernet2-master at version 1.0.2 in folder: C:\Program Files\Arduino\libraries\Ethernet2-master
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling for board Arduino/Genuino Uno.
#include <idDHT11.h>
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet2.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp2.h>
#include <Twitter.h>
#include <util.h>
EthernetServer server(80);
String readString = String(30); //string for fetching data from address
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0xB4, 0x00 }; //physical mac address
byte ip[] = { 10, 33, 211, 179 }; // ip in lan
Board int.0 int.1 int.2 int.3 int.4 int.5
Uno, Ethernet 2 3
Mega2560 2 3 21 20 19 18
Leonardo 3 2 0 1
Due (any pin, more info http://arduino.cc/en/Reference/AttachInterrupt)
This example, as difference to the other, make use of the new method acquireAndWait()
int idDHT11pin = 2; //Digital pin for comunications
int idDHT11intNumber = 0; //interrupt number (must be the one that use the previus defined pin (see table above)
//declaration
void dht11_wrapper(); // must be declared before the lib initialization
// Lib instantiate
idDHT11 DHT11(idDHT11pin,idDHT11intNumber,dht11_wrapper);
//start Ethernet
Ethernet.begin(mac, ip);
Serial.println("idDHT11 Example program");
Serial.print("LIB version: ");
Serial.println(IDDHT11LIB_VERSION);
Serial.println("---------------");
// This wrapper is in charge of calling
// mus be defined like this for the lib work
void dht11_wrapper() {
DHT11.isrCallback();
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100)
//store characters to string
readString += c; //replaces readString.append(c);
//output chars to serial port
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
//dirty skip of "GET /favicon.ico HTTP/1.1"
if (readString.indexOf("?") <0)
//skip everything
client.println("Content-Type: text/html");
client.println("<HTML>");
client.println("<HEAD>");
client.println(">Visit Scienceprog!</a>");
client.println();
//set background to yellow
client.print("<body style=background-color:red>");
//send first heading
//client.println("<font color='red'><h1>HTTP test routines</font></h1>");
client.println("<hr />");
//output some sample data to browser
client.println("<font color='blue' size='5'>Sample data: ");
client.println("<http-equiv=\"refresh\" content=\"1\">"); //testen
DHT11.acquire();
while (DHT11.acquiring())
int result = DHT11.getStatus();
switch (result)
case IDDHTLIB_OK:
Serial.println("OK");
case IDDHTLIB_ERROR_CHECKSUM:
Serial.println("Error\n\r\tChecksum error");
case IDDHTLIB_ERROR_ISR_TIMEOUT:
Serial.println("Error\n\r\tISR Time out error");
case IDDHTLIB_ERROR_RESPONSE_TIMEOUT:
Serial.println("Error\n\r\tResponse time out error");
case IDDHTLIB_ERROR_DATA_TIMEOUT:
Serial.println("Error\n\r\tData time out error");
case IDDHTLIB_ERROR_ACQUIRING:
Serial.println("Error\n\r\tAcquiring");
case IDDHTLIB_ERROR_DELTA:
Serial.println("Error\n\r\tDelta time to small");
case IDDHTLIB_ERROR_NOTSTARTED:
Serial.println("Error\n\r\tNot started");
default:
Serial.println("Unknown error");
Serial.print("Humidity (%): ");
client.println(DHT11.getHumidity(), 2);
client.println("</p>");
client.print("Temperature (oC): ");
client.println(DHT11.getCelsius(), 2);
client.print("Temperature (oF): ");
client.println(DHT11.getFahrenheit(), 2);
client.print("Temperature (K): ");
client.println(DHT11.getKelvin(), 2);
client.print("Dew Point (oC): ");
client.println(DHT11.getDewPoint());
client.print("Dew Point Slow (oC): ");
client.println(DHT11.getDewPointSlow());
//client.println("</body></html>");
Serial.print("\nRetrieving information from sensor: ");
Serial.print("Read sensor: ");
//delay(100);
Serial.println(DHT11.getHumidity(), 2);
Serial.print("Temperature (oC): ");
Serial.println(DHT11.getCelsius(), 2);
Serial.print("Temperature (oF): ");
Serial.println(DHT11.getFahrenheit(), 2);
Serial.print("Temperature (K): ");
Serial.println(DHT11.getKelvin(), 2);
Serial.print("Dew Point (oC): ");
Serial.println(DHT11.getDewPoint());
Serial.print("Dew Point Slow (oC): ");
Serial.println(DHT11.getDewPointSlow());
//clearing string for next read
//client.println("<http-equiv=\"refresh\" content=\"1\">"); //testen
//client.stop();
delay(20000);
