compiling sequence trouble shooting of existing program with multiple sensors
I found the Amazon library and deleted it and now it is gone. yeahhhhhh.
I will hunt down the other libraries and try to fix them next.
I had been trying to get the serial print to work to the serial monitor. It was just causing errors whereever I would put it in but I finally got it put in in a place it did not complain so now I have it posting messages to the serial monitor and am going through the code to find out where it does not go right. I have found that it is not doing the display correctly so that will be next. Probably using the wrong display. It is turned on but no data display on it.
