Compiling Time Very Slow / Upload error
Hello,
I have tried to do my due diligence and spent 20+hours trying to resolve this, but have had no luck.
I had been using version 1.8.3 of the Arduino software with no problems for the last 1.5 months, when out of the blue it now takes over a minute to "verify" a blank sketch. I have tried putting the arduino, arduino15, temp, and all arduino folders I can find into the excluded list of windows defender. I do not have any other antivirus software. My computer is a year old and running windows 10 and has ample ram, memory, etc. I have tried deleting the folder arduino15 and running a deep clean using Wise Registry Cleaner, installing the same / older versions of the software. The first code block below is when i "verify", the second is when I attempt to "upload" it onto my microcontroller, which is a uno. Both are for a blank script that appears when you click "new'. My microcontroller does not have any physical damage and currently has a program on it running a servo motor, so I know that it works. When I open the serial port and type something into it and click send, the RX light on the microcontroller lights up, and I have gone into device manager to confirm its driver is up to date. I am at a total loss here and contemplating buying a new computer. Any help is much appreciated.
Thank you for your time,
Curtis
Looking for library 'user32'
Adding paths from jna.library.path: null
Trying user32.dll
Found library 'user32' at user32.dll
Looking for library 'shell32'
Trying shell32.dll
Found library 'shell32' at shell32.dll
Looking for library 'Ole32'
Trying Ole32.dll
Found library 'Ole32' at Ole32.dll
Loading configuration...
Initializing packages...
Preparing boards...
Starting…
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Curtis\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847 -warnings=default -build-cache C:\Users\Curtis\AppData\Local\Temp\arduino_cache_374561 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Curtis\Documents\Arduino\sketch_jul21b\sketch_jul21b.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
WARNING: Category 'Real-time clock' in library DS3231 is not valid. Setting to 'Uncategorized'
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\sketch\sketch_jul21b.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\sketch\sketch_jul21b.ino.cpp" -o "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os  -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\sketch\sketch_jul21b.ino.cpp" -o "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\sketch\sketch_jul21b.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\core\wiring_pulse.S.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os  -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp" -o "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\core\HardwareSerial.cpp.o"
Using proxy DIRECT
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os  -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\new.cpp" -o "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\core\core.a" "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847\core\wiring_pulse.S.o"
Archiving built core (caching) in: C:\Users\Curtis\AppData\Local\Temp\arduino_cache_374561\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc"  -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847/sketch_jul21b.ino.elf"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Curtis\AppData\Local\Temp\arduino_build_386847/sketch_jul21b.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x9a
… (continued until 10 of 10) …
avrdude done.  Thank you.
(deleted)
Yes, I have already tried that.
Hi curtisfrom
Going to throw a couple of things as attachments.
There will be parts you can ignore but for windows some of the items mentioned may help.
Arduino troubleshooting made easy.pdf (522 KB)
CLEAN UP BEFORE INSTALLING ANOTHER COPY OF THE IDE OR ARDUINO CREATE.pdf (345 KB)
