how do you fix an arduino compiling error?
By fixing the source of the error
That depends on what it is ?
Keeping compile errors secret will only get you a secret answer that you cannot see
Try reading this post and add some detail to your question.
You can pay someone to do it on Gigs and Collaborations.
Press Control-A and then press the delete key. Errors all gone.
baconeer:
By realizing that it's not the compiling that's in error, it is what is being compiled.
Google "C++ tutorial" and do a C++ tutorial.
PaulMurrayCbr:
It's premature to say that without seeing the error; for example, he could be using 1.8.1 or earlier on Windows XP, or his AV program could be mistakenly interfering with the compilation process, or he could have gotten his Arduino IDE installation into one of several other possible bad states that cause all attempts to compile to fail - of course, it's most likely that the problem is with the code he's attempting to compile, in which case the compiler error will throw errors pointing out the line where it realized there was a problem.
OP must post error in order for us to help (this is important whenever asking for any form of technical assistance - always post the full text of any and all error messages.)
Delta_G:
It will still complain about missing setup() and loop().
