Complement operator turning uint8_t to signed number
Hi I am Siddhesh and I am an intermediate level arduino user,
I am trying to read PORT C and check for different combinations at port C from the eight relay
My doubt is
when I use complement(~ operator) after left shifting(<< operator) a uint8_t number is just gives me answer in 16 bit form
My Code:-
enum relay_pins {START, UP, DOWN, LEFT, RIGHT, FWD, REV, ALARM};
int port_c=254;
uint8_t spam=1;
{ Serial.begin(115200);
Serial.println(sizeof(spam));
Serial.println(sizeof(~(spam)));
Serial.println(sizeof(spam<<LEFT));
Output:-
1
2
2
for my doubt, sorry if this is a silly question but just started to learn in deep of bit manipulation
Welcome to the forum
Use [color = red]code tags[/color] (the </> icon above the compose window) to make it easier to read and copy for examination
What is the question?
Why a shift or complement operator converting a unsigned 8 bit integer to signed integer of 16 bits
My Code:-
int port_c=254;
uint8_t spam=1;
Output:-
1
2
2
Do not post images of code or Serial monitor output. Follow the advice in the link I posted
Done sir, can you please guide me on the issue?
This is because of numeric promotion. Bitwise operators work on integers, when smaller types are used they are automatically promoted.
https://en.cppreference.com/w/cpp/language/implicit_conversion#Numeric_promotions
[edit]
By the way, here is a trick that may help when you want to know the type of a value.
template <class T> void show(T) {
  Serial.println(__PRETTY_FUNCTION__);
  show('a');
  show('a' << 1);
This results in:
void show(T) [with T = char]
void show(T) [with T = int]
Thanks, it really helped me understand, I worked around it by just converting it again into a uint8_t after doing my << and ~ operations.
Is there any more effecient way?
My workaround:-
uint8_t spam=1;
Serial.println(sizeof(spam));  // 8bit unsigned
Serial.println(sizeof(~(spam)));  // 16 bit signed
Serial.println(sizeof(spam<<LEFT));  // 16 bit signed
Serial.println (uint8_t(~(spam<<START))) ; // 8 bit unsigned
not too sure what you're are trying to achieve, but simply writing this as code ensures that 'spam' is always an 8bit unsigned value...
uint8_t spam=1;
spam = ~spam;
Serial.println(sizeof(spam)); //8 bit unsigned
spam<<=LEFT;
spam = ~(spam<<START);
Serial.println (sizeof(spam)); //8 bit unsigned
hope that helps....
Not that I know of. It will be converted back to an uint8_t as soon as you assign it to a variable of that type.
If it really bothers you, perhaps you can use a function, e.g.,
uint8_t shl(uint8_t const v, size_t const n) {
  return v << n;
Works great!!
Thanks for the help got it :slight_smile:
