Complementary PWM channels Output
Sorry, I noticed that I omitted the dead-time enable bit in my description above. You just need to set the DTE bit in the Due's Channel Mode Register (CMRx) for the given PWM channel, for example for channel 0:
PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_DTE | PWM_CMR_CPRE_CLKA;
How does the dead time operate for synchronous channels? I'm putting in dead times and it significantly reducing my period value. When using in synchronous channels, do you have to just enable it on channel 0 and use channel 0's clock? or you have to enable for each channel and use the clock for each channel? my period value is supposed to be 0.002777778, but i'm getting 0.001933333 when I insert dead times. Even with '0' in the DTH and DTL I'm still getting 0.001933333.
I just want to get a dead time of about 1 micro second
When the DTE bit is disabled, I'm getting the correct period 0.002777778s, but when DTE is enabled, regardless of what I put in the DTH and DTL registers, I'm still getting a period of 0.0019333333s. Both complementary outputs look exactly the same on the oscilloscope also, one isn't slightly bigger and the other and both start and end on the exact same time intervals.
Dead-time insertion doesn't actually change the period of the complementary waveforms, it simply delays the waveforms' edge with respect to the beginning of the timer cycle.
If the duty-cycle (and period) of the waveform remains unchanged then inserting a delay will shorten the pulse width. To maintain the pulse width it's necessary to add the delay time to the duty-cycle register, in order to extend it oncemore, however this can only be achieved so long as the duty-cycle does not exceed the period.
An example of using dead-time insertion is given in post number #10 here: How do I make a PWM signal run once only. - Arduino Due - Arduino Forum.
This example shows how it works for 1 channel, how does dead time work for three synchronized channels? like how I have CH0, CH1 and CH2 synchronized.
You just have to set the dead time enable bit for each channel:
PWM->PWM_CH_NUM[1].PWM_CMR = PWM_CMR_DTE;                         // Enable channel 1 dead-time insertion
Here's an example with 3 pairs of complementary and synchronous PWM outputs at 100kHz:
// Enable synchronous, complementary output, single-slope PWM at 100kHz on 3 channels (0 to 2), at 75% duty cycle
// with various dead-times for each channel
  // Set-up 6 PWM outputs on 3 complementary channels on on pins D34, D35, D36, D37, D38, and D39 for channels 0 through to 2 respectively
  PMC->PMC_PCER1 |= PMC_PCER1_PID36;                                // Enable PWM
  PIOC->PIO_ABSR |= PIO_ABSR_P7 | PIO_ABSR_P6 |                     // Set the port C PWM pins to peripheral type B
                    PIO_ABSR_P5 | PIO_ABSR_P4 |
                    PIO_ABSR_P3 | PIO_ABSR_P2;
  PIOC->PIO_PDR |= PIO_PDR_P7 | PIO_PDR_P6 |                        // Set the port C PWM pins to outputs
                   PIO_PDR_P5 | PIO_PDR_P4 |
                   PIO_PDR_P3 | PIO_PDR_P2;
  PWM->PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(1);                 // Set the PWM clock A rate to 84MHz (84MHz/1)
  PWM->PWM_SCM |= PWM_SCM_UPDM_MODE1 |                              // Automatically update the duty-cycle register each timer cycle
                  PWM_SCM_SYNC2 | PWM_SCM_SYNC1 | PWM_SCM_SYNC0;    // Set the PWM channels as synchronous
  PWM->PWM_CH_NUM[0].PWM_CPRD = 839;                                // Set the PWM frequency to 100kHz (84MHz/(839 + 1)) for all synchronous channels
  PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_DTE | PWM_CMR_CPRE_CLKA;     // Enable channel 0 dead-time insertion and set the clock source as CLKA for all synchronous channels
  PWM->PWM_CH_NUM[2].PWM_CMR = PWM_CMR_DTE;                         // Enable channel 2 dead-time insertion
  PWM->PWM_CH_NUM[0].PWM_CDTY = 630;                                // Set channel 0 PWM duty cycle to 75%
  PWM->PWM_CH_NUM[1].PWM_CDTY = 630;                                // Set channel 1 PWM duty cycle to 75%
  PWM->PWM_CH_NUM[2].PWM_CDTY = 630;                                // Set channel 2 PWM duty cycle to 75%
  PWM->PWM_CH_NUM[0].PWM_DT = PWM_DT_DTH(0) | PWM_DT_DTL(0);        // Set channel dead-time for a 0us delay on output PWML0
  PWM->PWM_CH_NUM[1].PWM_DT = PWM_DT_DTH(0) | PWM_DT_DTL(105);      // Set channel dead-time for a 1.25us delay on output PWML1
  PWM->PWM_CH_NUM[2].PWM_DT = PWM_DT_DTH(0) | PWM_DT_DTL(210);      // Set channel dead-time for a 2.5us delay on output PWML2
  PWM->PWM_ENA = PWM_ENA_CHID0;                                     // Enable all synchronous PWM channels
void loop() {}
Here's the output top to bottom of channels PWML0, PWML1, PWML2 and PWMH0 respectively:
PWML0 (yellow) and its complement PWMH0 (dark blue) have no dead-time insertion, PWML1 (light blue) has 1.25us of dead-time insertion, while PWML2 (pink) has 2.5us.
How do I update the dead time every period, because I tried what you showed me in #26 but the dead times aren't being inserted. I'm still just getting both complementary wave-forms being exactly the same.
/* This code generates Quasi-Square Waves at 60Hz*/
static byte stateCount = 0;
static float CPRDV = 0;
static float inverterFrequency = 60;
int divA = 42;      // Set DIVA
  Serial.begin(57600);
  PMC->PMC_PCER1 |= PMC_PCER1_PID36;                  // Enable PWM (Power On)
  PIOC->PIO_PDR |= PIO_PDR_P3 | PIO_PDR_P5 | PIO_PDR_P7;           // Setting pins 3,5,7 (DUE Pins 35, 37, 39) to PWM Peripheral, not GPIO
  PIOC->PIO_ABSR |= PIO_ABSR_P3 | PIO_ABSR_P5 | PIO_ABSR_P7;       // Setting pins to Peripheral B
  PIOC->PIO_PDR |= PIO_PDR_P2 | PIO_PDR_P4 | PIO_PDR_P6;           // Setting pins 2,4,6 (DUE Pins 34, 36, 38) to PWM Peripheral, not GPIO
  PIOC->PIO_ABSR |= PIO_ABSR_P2 | PIO_ABSR_P4 | PIO_ABSR_P6;       // Setting pins to Peripheral B
  PWM->PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(divA);  // Set PWM clocke rate to 2MHz (84MHz/42)
  PWM->PWM_SCM |= PWM_SCM_SYNC0 | PWM_SCM_SYNC1 | PWM_SCM_SYNC2;      // Synchronizing of Channels 0, 1 and 2
  PWM->PWM_SCM |= PWM_SCM_UPDM_MODE1;                 // Manual Write of duty-cycle automatic trigger of the update
  NVIC_SetPriority(PWM_IRQn, 0);                      // Set the Nested Vector Interrupt Controller (NVIC) priority for the PWM controller to 0 (highest)
  NVIC_EnableIRQ(PWM_IRQn);                           // Connect PWM Controller to Nested Vector Interrupt Controller (NVIC)
  PWM->PWM_IER1 = PWM_IER1_CHID0;                     // Enable interrupt on PWM channel 0 triggered at end of PWM period
  calcCPRDV();  // CPRD is calculated
  /*Serial.print("CPRDV = ");
  Serial.print(CPRDV);
  Serial.print("\n");*/
  PWM->PWM_CH_NUM[0].PWM_CPRD = CPRDV;                // Channel 0 Period f = 2MHz/(CPRD)= 100Hz = 0.01s |CPRD = 2MHz/f
  PWM->PWM_CH_NUM[0].PWM_CMR = PWM_CMR_CPRE_CLKA | PWM_CMR_DTE;     // Period is left aligned,clock source is CLKA on Channel 0
  PWM->PWM_CH_NUM[0].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(2);
  PWM->PWM_CH_NUM[1].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(2); // Dead time of 1us [DT = (1/2778)*5555 = 2
  PWM->PWM_CH_NUM[2].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(2);
  PWM->PWM_ENA = PWM_ENA_CHID0;                       // Enable synchronous PWM on Channel 0
void PWM_Handler()                       // PWM Interrupt Service Routine (ISR)
  if (PWM->PWM_ISR1 & PWM_ISR1_CHID0)    // Check if an update condition has occured
    update_Duty_Cycle();                 // Update the duty cycles
void calcCPRDV () // Used to calculate the CPRD value
  //inverterFrequency = 60;
  static float numOfVectors = 6;
  static float adMCKFreq = 84000000;
  static float timerFreq = (adMCKFreq/divA); //2MHz
  static float period = 1/inverterFrequency;
  static float Ts = period/numOfVectors;
  static float switchingFreq = 1/Ts;
  CPRDV = (timerFreq/(1*switchingFreq));
  /*Serial.print("Inverter Frequency = "); Serial.print(inverterFrequency);Serial.print("\n");
  Serial.print("Num of Vectors = "); Serial.print(numOfVectors); Serial.print("\n");
  Serial.print("Timer Freq = "); Serial.print(timerFreq); Serial.print("\n");
  Serial.print("Period = "); Serial.print(period, 8); Serial.print("\n");
  Serial.print("SSV Period = "); Serial.print(Ts, 8); Serial.print("\n");
  Serial.print("Switching Freq = "); Serial.print(switchingFreq); Serial.print("\n");*/
void update_Duty_Cycle()
    if(stateCount < 6)
          PWM->PWM_CH_NUM[0].PWM_CDTYUPD = 0;
          PWM->PWM_CH_NUM[1].PWM_CDTYUPD = 0;
          PWM->PWM_CH_NUM[2].PWM_CDTYUPD = 0;
          stateCount++;
          /*Serial.print("Counter = ");
          Serial.print(stateCount); Serial.print("\n");*/
      static byte count = 0;
      static float p = CPRDV;
      static float n = 0;
      //Serial.print("Sector = "); Serial.print(count); Serial.print("\n");
      switch(count)
          case 0: //pnn = 100 => 012
            PWM->PWM_CH_NUM[0].PWM_CDTYUPD = p;
            PWM->PWM_CH_NUM[1].PWM_CDTYUPD = n;
            PWM->PWM_CH_NUM[2].PWM_CDTYUPD = n;
            PWM->PWM_CH_NUM[0].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(20);
            PWM->PWM_CH_NUM[1].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(20);
            PWM->PWM_CH_NUM[2].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(20);
          case 1: //ppn = 110 => 012
            PWM->PWM_CH_NUM[1].PWM_CDTYUPD = p;
          case 2: //npn = 010 => 012
            PWM->PWM_CH_NUM[0].PWM_CDTYUPD = n;
          case 3: //npp = 011 => 012
            PWM->PWM_CH_NUM[2].PWM_CDTYUPD = p;
          case 4: //nnp = 001 => 012
          case 5: //pnp = 101 => 012
          default:
        count = (count + 1) % 6;
I just want a deadtime of 1us, my CPRD value is 5555 and my period is 2778us, therefore DT=(1/2778)*55555 = 1.999 = 2. When i look at it on an oscilloscope I'm not seeing the dead time. So I'm thinking that I need to update the dead time every period for them to show up.
Have you zoomed into (with the time base) and compared the leading edges of the synchronised PWM waveforms on your scope? A 1us (1/2MHz * 2) dead-time is hardly anything in comparison to the 2778us period.
During operation it's also possible to use the dead-time insertion update registers. These update the dead-time at the beginning of the next timer cycle, in a similar fashion to the duty-cycle update registers:
PWM->PWM_CH_NUM[0].PWM_DTUPD = PWM_DTUPD_DTHUPD(0) | PWM_DTUPD_DTLUPD(2);
When I try using the code in #28, the IDE tells me "PWM_DT_DTHUPD" and "PWM_DT_DTLUPD" was not declared in this scope.
An yes I zoomed in on the oscilloscope to see if I was getting the dead times, I went as far as 5us and still wasn't seeing the dead times
I've now corrected it above, it's
Are your looking at the low side channel outputs, PWMLx, on your scope?
I'm looking at both low side and high side for each channel in turn to compare.
I tried the code in #30 and still nothing. This is my code:
int divA = 42;
  //Serial.begin(57600);
  calcCPRDV();
  //PWM->PWM_CH_NUM[0].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(200);
  //PWM->PWM_CH_NUM[1].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(200);
  //PWM->PWM_CH_NUM[2].PWM_DT = PWM_DT_DTH(0)| PWM_DT_DTL(200);
void calcCPRDV ()
    if(stateCount < 6)
          stateCount++;
      static float n = 0;
      switch(count)
            PWM->PWM_CH_NUM[0].PWM_DTUPD = PWM_DTUPD_DTHUPD(0)| PWM_DTUPD_DTLUPD(2);
            PWM->PWM_CH_NUM[1].PWM_DTUPD = PWM_DTUPD_DTHUPD(0)| PWM_DTUPD_DTLUPD(2);
            PWM->PWM_CH_NUM[2].PWM_DTUPD = PWM_DTUPD_DTHUPD(0)| PWM_DTUPD_DTLUPD(2);
          default:
Could it be that the UPDULOCK bit must be set in order to allow the dead time registers to be updated?
Any luck? I've tried everything I can think of, and it's not working.
MartinL, If I would like to set the period of the pwm from a function, but the function takes input from a keypad and then uses the value inputted by the keypad to choose a case in a switch, how would be the best way to go about doing that?
To change the period of the signals just requires you to change the period PER registers for channel 0:
As your PWM signals span across a number of PWM cycles, I imagine it would be easiest to place to insert this line is in your update_Duty_Cycle() function, specifically in the one of the 6 output states. This also ensures that any changes happen at the beginning of your state output cycle.
To select differing periods your keypad could set a variable either containing the period or that can be used to select a preset period in the update_Duty_Cycle() function. As the update_Duty_Cycle() function is called from within the PWM_Handler(), but set by the keypad from outside it, it will be necessary to declare the variable as "volatile":
volatile unsigned long periodValue;
So if I want to be able to set the period value before the program even starts with the first duty cycle value I should do something like at the top of my handler
if (x <1)
      setPeriod();
      x++
And in this set period function I include the code that would allow the keypad to set the value of the period? Adding it to the top of the handler ensures that it is executed before any switching starts
If it's done this way I'm guessing it will remain in the function as long as the person is setting the period value. But after that it'll never enter that loop again because x would be equal to 1. What you think?
