Complementary PWM on the Due
Good day,
I've tried the code given on this forum post to generate complementary PWM signals:
https://forum.arduino.cc/index.php?topic=527573.0
But when I change the period and duty cycle the circuit behaves unexpectedly. When I have the duty cycle set to 100% the PWML2 pin outputs a high abd when I have the duty cycle at 0% the PWMH2 pin outputs a high. Also for even number duty cycles such as 100%, 80%, 60%..... the PWML2 outluts high while for 90, 70, 50...... The two pins output values. can someone clarify got me how this code is supposed to work?
Where is your code ?
In some PWM the PWM_CDTY is the off time the H and L shows you that, H duty equals off time, L duty equal on time.
I tested the PWMH2, if you put a LED over it as high the duty goes the LED gets darker.
I also tested the PWML6 and PWML7 and the behavior is the expected as high is the duty goes more bright the led gets.
Here https://forum.arduino.cc/index.php?topic=453208.0 post #4 how to enable 8 PWM channels for testing
Thank you
