Complete newbie - Need help selecting parts for my application (DC motors and boards)
I have never built anything like this myself, but I'm hoping someone can help guide me in the right direction. I am building a little mini lathe as a display piece, but want it to have some function. The lathe will be made out of 3d printed parts.
Here is what i need im trying to accomplish:
I need 2x DC motor that runs off 6v or less. Spins approx 200rpm, and i want to be able to flip a switch to reverse the direction of it.
I need 2x DC motors (6v or less) that can spin up to 200 rpms, but the speed can be controlled with a twist knob.
I want to hook up all the motors to one board (not even sure where to start here) and have switches that control each motor.
Sorry for the inexperience, but I would appreciate any help. Please ask any questions and i will try my best to answer.
You need a center-off switch so you can STOP the motor before you revers the direction! Speed can be controlled with a wire-wound potentiometer in series with the motor power supply. No need for any Arduino for this project!
I understand it may not be necessary to go this route, but it's a skill i need to develop and i feel like this might be a good start.
As impractical as it may seem for this project, would you mind sharing some insite on what ill need to do it with arduino?
Ill also probably end up adding a little lcd screen and limit switches for the movement
When you finally decide what you want to build and have selected the motors, then we can continue.
Here is the motor I had in mind.
If you have a better motor in mind that is equivalent, i would happily take that advice too.
As for what i want to build..
I will have 4 of these motors total. 2 of them i need to be able to control the speed with two separate twist knobs. The other two i would like separate switches that control the direction of the rotation.
