Please,
do you know if there is a way to hard reset Arduino Yun, in order to have default settings (lan, wifi etc...), as when I open for the first time?
Thanks
Please,
Thanks
Resetting the processors (AR9331, WiFi, and 32U4)
To restart the AR9331, which reboots Linino, press the "YÚN RST" reset button that is close to the analog inputs pins and the LEDs of the board.
To restart the the 32U4 and restart the currently installed Arduino sketch, tap the button next to the Ethernet port two times.
The reset button for WiFi is located next to the USB-A connector. When you press the button, the WLAN LED will flash.
If you move to a different network and can no longer wirelessly access the Yún through its web interface, you can reset the Yún's network configuration by pressing the Wifi reset button for longer longer than 5 seconds, but less than 30, the AR9331 processor will reboot. The WiFi configuration will be reset and the Yún will start its own wiFi network Arduino Yún-XXXXXXXXXXXX. Any other modification/configuration will be retained.
To reset the Linino distribution to its default state, press the WiFi reset button for at least 30 seconds. The board reverts to the original settings as if it had been reflashed or taken out of the box. Among other things, this removes all installed files and network settings.
