Component for driving 8 low power motors
Hello,
I'm looking to build a multi-plant watering rig and need to drive up to 8 small water pumps rated at 3-5V < 200ma, possibly 500ma. Link to Motor
I plan on using 5V DC input voltage, which I also want to use to power the motors, controlled by a 3.3V microcontroller (Adafruit Feather 32u4).
I was initially planning to use several 2N7000-G MOSFETs, but this would require me to wire in many additional pull-down resistors and kickback diodes (based on this tutorial)
I was wondering whether there are any other options, ideally in a DIP package which can also give me 8 channels to switch these motors. I was looking at something like ULN2803A, but I'm worried about the voltage drop which seems to be up to 1.6V max, and as I understand my motors will only be getting 5V-1.6V -> 3.4., Although this is within the range for my motors, I was hoping for something with a lower voltage drop.
Can anyone suggest a good component for my needs?
Thanks in advance,
eyjohn
Relay contacts have almost zero voltage drop.
Paul
Paul_KD7HB:
Paul
Thanks for the suggestion, looks like a good option, a bit larger than I was hoping for but is definitely a good fallback
Darlington's like the ULN2803 indeed drop a lot of voltage. Single BJT's are much
better for this, though more limited in current handling:
2N2222A switching transistors can handle upto 600mA or so - use a 100 ohm base
resistor.
If that's not enough the rather more exotic ZTX851's can handle significantly more
current as they are super-beta devices able to switch upto 50 times the base current
(most switching transistors can handle 10 to 20 times the base current).
With 30mA from the microcontroller pin, that's 1.5A rather than just 600mA for
the ZTX851's.
Logic level MOSFETs are the other choice.
MarkT:
resistor.
the ZTX851's.
Thanks for the input MarkT
How about using a FET type transistor array?
e.g. TBD62381APG
It has lower on-resistance than bipolar type.
And built-in freewheel diode on all channels.
Furthermore, it's included an input circuit and can be directly connected to a 5V microcontroller.
Additional external component needed is a capacitor only.
The TBD62381APG has a worst-case on-resistance rating of 2.5 ohms, which isn't great, with 8 devices
in one package that might have the same thermal issues as an octal darlington.
Well that's a bit moot, its best/worst case seems to straddle the 2N2222A's performance.
The best bipolar I know (ZTX851) is more expensive but has about 0.1 ohms at 1A - if only
you could get an array of those in one package(!).
If thermal issues might be a problem, 8 separate 2N2222's should be able dissipate more heat than
one DIP18, given suitable PCB area.
