component to play recording voice
Hello guys i was doing a project about door lock using an rfid with voice recorder. i managed to wire all of them but im stuck on voice recorder. i was using wtv020 to play the sound.
My project works like this.
if you tag with the registered rfid tag, then the voice recorder will play " access accepted " then the key unlocked.
if you tag with the unregistered rfid tag, then the voice recorder will play " access denied " then the key is still locked.
my component is :
  • rfid
  • solenoid door lock 12V
  • arduino uno
  • relay 1 channel
  • speaker
  • power supply 12V
  • wtv020 SD 16 pin
Im so confused with wtv020, can i use other module like sd card module, ISD 1820, or etc ?
thank you very much :slight_smile:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.... :slight_smile:
