I’m using an Arduino Uno and want to control a 632 nm laser diode so it can be turned ON and OFF through the Arduino.
The laser diode will be mounted externally on a holder, not on the breadboard .I just want the Arduino to handle the switching part.
I’m a bit unsure what components I’ll actually need to make this work safely and simply.
Could someone please explain:
What parts I should get for this setup?
How they would roughly connect together?
Any tips to keep it simple and safe for a beginner?
A bare laser diode need some kind of driver circuit. Sometimes it's just a current limiting resistor (like what's used with a regular LED) or sometimes in a cheap laser pointer it's just the internal resistance of the battery.
Usually laser diodes have an internal photodiode and a 3rd connection so the driver can monitor the actual light output and keep it constant. A better circuit will monitor the actual light output in a feedback loop.
If you mean you have a 'flashlight' like device, then open it up and connect wires to either side of the existing switch. Run those wires back to a small relay and connect them to G and NO. Now connect the relay to the Arduino per usual, and a couple of lines of code will turn the relay on via a push button.
where you can read details about power supply, output power control and the use of PWM ("The Survelase Maxi laser is also available with a TTL driver board that allows the unit to be gated on and off, or pulse-width modulated at TTL voltage levels via the yellow control lead.")
However: This laser module is not unconditionally eyesafe!!! This is the classification as provided in the spec listed above:
