Composite Device (CDC,MSC) has error 10 in Windows
I've created MSC Device as PluggableModule.
In Linux it works, I can mount my "thumb drive" based on SAMD21, and read/write to SD card from OS.
But Windows shows error 10 on Composite Device.
I do not understand what is wrong, all descriptors are according to specs.
Here is what USB Tree Viewer shows
=========================== USB Port2 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 2-2
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB Composite Device
Device Path : \.\usb#vid_239a&pid_800b#4e75e52d504d5741372e3120ff141506#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_239A&PID_800B\4E75E52D504D5741372E3120FF141506
Hardware IDs : USB\VID_239A&PID_800B&REV_0100 USB\VID_239A&PID_800B
Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0014 (GUID_DEVCLASS_USB)
Driver : system32\DRIVERS\usbccgp.sys (Version: 6.1.7601.18328 Date: 2013-11-26)
Driver Inf : C:\Windows\inf\usb.inf
Legacy BusType : PNPBus
Class : USB
Class GUID : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : usbccgp
Enumerator : USB
Location Info : Port_#0002.Hub_#0002
Location IDs : PCIROOT(0)#PCI(0A01)#USBROOT(0)#USB(2)
Container ID : {a2ee37de-d179-5241-b507-d4e97f4c2838}
Manufacturer Info : (Standard USB Host Controller)
Capabilities : 0x14 (Removable, UniqueID)
Status : 0x01806400 (DN_HAS_PROBLEM, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 10 (CM_PROB_FAILED_START)
Address : 2
Power State : D3 (supported: D0, D1, D2, D3, wake from D0, wake from D1, wake from D2)
---------------- Connection Information ---------------
Connection Index : 0x02 (2)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x00
Device Address : 0x02 (2)
Is Hub : 0x00 (no)
Number Of Open Pipes : 0x00 (0)
Device Bus Speed : 0x01 (Full-Speed)
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x200 (USB Version 2.00)
bDeviceClass : 0xEF (Miscellaneous)
bDeviceSubClass : 0x02
bDeviceProtocol : 0x01 (IAD - Interface Association Descriptor)
bMaxPacketSize0 : 0x40 (64 bytes)
idVendor : 0x239A
idProduct : 0x800B
bcdDevice : 0x0100
iManufacturer : 0x01 (String Descriptor 1)
iProduct : 0x02 (String Descriptor 2)
iSerialNumber : 0x03 (String Descriptor 3)
bNumConfigurations : 0x01 (1 Configuration)
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0062 (98 bytes)
bNumInterfaces : 0x03 (3 Interfaces)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0xA0
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x01 (yes)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0xFA (500 mA)
------------------- IAD Descriptor --------------------
bLength : 0x08 (8 bytes)
bDescriptorType : 0x0B
bFirstInterface : 0x00
bInterfaceCount : 0x02
bFunctionClass : 0x02 (Communications and CDC Control)
bFunctionSubClass : 0x02
bFunctionProtocol : 0x00
iFunction : 0x00 (No String Descriptor)
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00
bAlternateSetting : 0x00
bNumEndpoints : 0x01 (1 Endpoint)
bInterfaceClass : 0x02 (Communications and CDC Control)
bInterfaceSubClass : 0x02 (Abstract Control Model)
bInterfaceProtocol : 0x00 (No class specific protocol required)
iInterface : 0x00 (No String Descriptor)
Continue on next messgae
... continued
-------------- CDC Interface Descriptor ---------------
bFunctionLength : 0x05 (5 bytes)
bDescriptorType : 0x24 (Interface)
bDescriptorSubType : 0x00 (Header Functional Descriptor)
bcdCDC : 0x110 (CDC Version 1.10)
bFunctionLength : 0x04 (4 bytes)
bDescriptorSubType : 0x02 (Abstract Control Management Functional Descriptor)
bmCapabilities : 0x06
D7..4: : 0x00 (Reserved)
D3 : : 0x00 (not supports the notification Network_Connection)
D2 : : 0x01 (supports the request Send_Break)
D1 : : 0x01 (supports the request combination of Set_Line_Coding, Set_Control_Line_State, Get_Line_Coding, and the notification Serial_State)
D0 : : 0x00 (not supports the request combination of Set_Comm_Feature, Clear_Comm_Feature, and Get_Comm_Feature)
bDescriptorSubType : 0x06 (Union Functional Descriptor)
bControlInterface : 0x00
bSubordinateInterface[0] : 0x01
bDescriptorSubType : 0x01 (Call Management Functional Descriptor)
bmCapabilities : 0x01
D7..2: : 0x00 (Reserved)
D1 : : 0x00 (sends/receives call management information only over the Communication Class interface)
D0 : : 0x01 (handles call management itself)
bDataInterface : 0x01
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x03 (TransferType=Interrupt)
wMaxPacketSize : 0x0010 (16 bytes)
bInterval : 0x10 (16 ms)
bInterfaceNumber : 0x01
bNumEndpoints : 0x02 (2 Endpoints)
bInterfaceClass : 0x0A (CDC-Data)
bInterfaceSubClass : 0x00
bEndpointAddress : 0x02 (Direction=OUT EndpointID=2)
bmAttributes : 0x02 (TransferType=Bulk)
wMaxPacketSize : 0x0040 (64 bytes)
bInterval : 0x00 (ignored)
bEndpointAddress : 0x83 (Direction=IN EndpointID=3)
bInterfaceNumber : 0x02
bInterfaceClass : 0x08 (Mass Storage)
bInterfaceSubClass : 0x06 (SCSI transparent command set)
bInterfaceProtocol : 0x50 (Bulk­Only Transport)
bEndpointAddress : 0x04 (Direction=OUT EndpointID=4)
wMaxPacketSize : 0x0200 (512 bytes)
bEndpointAddress : 0x85 (Direction=IN EndpointID=5)
-------------------- String Descriptors -------------------
String descriptors are not available (because the device has problem code CM_PROB_FAILED_START)
my project is at https://github.com/markmal/MSD
