J'essaie de faire marcher ce code, il se compile bien se téléverse bien mais toutes les leds s'allument et il ne se passe rien.
Ma question est la suivante : voyez vous une erreur qui vous saute au yeux afin de pouvoir m'aiguiller?
Merci,
#include <MD_MAX72xx.h>
#include <SPI.h>
#define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
//#define HARDWARE_TYPE MD_MAX72XX::PAROLA_HW
#define CLK_PIN 13 // or SCK
#define DATA_PIN 11 // or MOSI
#define CS_PIN 10 // or SS
#define BUTTON_LEFT_PIN 6 // Data Pin for Left Button
#define BUTTON_RIGHT_PIN 7 // Data Pin for Right Button
long buttonTimerR = 0;
long longPressTimeR = 500;
boolean buttonActiveR = false;
boolean longPressActiveR = false;
long buttonTimerL = 0;
long longPressTimeL = 500;
boolean buttonActiveL = false;
boolean longPressActiveL = false;
// SPI hardware interface
//MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
// Arbitrary pins
MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Text parameters
#define CHAR_SPACING 1 // pixels between characters
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char message[BUF_SIZE] = {" 000"};
bool newMessageAvailable = true;
int currentScoreLeft = 0,
currentScoreRight = 0;
int lastNumberPushup = 0;
bool resetBeforeFirstUse = true;
bool hasLeftDownState = true;
String howMuchSpace;
void printText(uint8_t modStart, uint8_t modEnd, char *pMsg) // *************** LED MATRIX PRINT FUNCTION ***************
// Print the text string to the LED matrix modules specified.
// Message area is padded with blank columns after printing.
uint8_t state = 0;
uint8_t curLen;
uint16_t showLen;
uint8_t cBuf[8];
int16_t col = ((modEnd + 1) * COL_SIZE) - 1;
mx.control(modStart, modEnd, MD_MAX72XX::UPDATE, MD_MAX72XX::OFF);
do // finite state machine to print the characters in the space available
switch(state)
case 0: // Load the next character from the font table
// if we reached end of message, reset the message pointer
if (*pMsg == '\0')
showLen = col - (modEnd * COL_SIZE); // padding characters
state = 2;
// retrieve the next character form the font file
showLen = mx.getChar(*pMsg++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
curLen = 0;
state++;
// !! deliberately fall through to next state to start displaying
case 1: // display the next part of the character
mx.setColumn(col--, cBuf[curLen++]);
// done with font character, now display the space between chars
if (curLen == showLen)
showLen = CHAR_SPACING;
state = 2;
case 2: // initialize state for displaying empty columns
curLen = 0;
state++;
// fall through
case 3: // display inter-character spacing or end of message padding (blank columns)
mx.setColumn(col--, 0);
curLen++;
state = 0;
default:
col = -1; // this definitely ends the do loop
} while (col >= (modStart * COL_SIZE));
mx.control(modStart, modEnd, MD_MAX72XX::UPDATE, MD_MAX72XX::ON);
void setup() // ********************* SETUP ********************
mx.begin();
// Code written for IR 06H, EN not used, so jumper should be plugged.
// initialize the pushbutton pin as an input:
pinMode(BUTTON_LEFT_PIN, INPUT);
pinMode(BUTTON_RIGHT_PIN, INPUT);
Serial.begin(9600); // Serial for debuggin, should be off on final to avoid delays
// myDisplay.setIntensity(0);
// Serial.begin(9600);
void loop() // ********************* LOOP ********************
int buttonStateLeft = digitalRead(BUTTON_LEFT_PIN);
int buttonStateRight = digitalRead(BUTTON_RIGHT_PIN);
Serial.println(buttonStateRight);
if (true == true) // LED Matrix Updater
String messageUpdater;
// Space Manager
if (currentScoreLeft <= 9 && currentScoreRight <= 9){
howMuchSpace = " ";
} else if (currentScoreLeft >= 10 && currentScoreRight <= 9){
howMuchSpace = " ";
} else if (currentScoreLeft <= 9 && currentScoreRight >= 10){
howMuchSpace = " ";
} else if (currentScoreLeft >= 10 && currentScoreRight >= 10){
howMuchSpace = " ";
howMuchSpace = " ";
messageUpdater = String(currentScoreLeft) + howMuchSpace + String(currentScoreRight); // Creates space between numbers
messageUpdater.toCharArray(message,10); // how many numbers to load
printText(0, MAX_DEVICES-1, message); // update message using LED Matrix Function
newMessageAvailable = false;
// RIGHT BUTTON CODE ******************************************************************
if (buttonStateRight == HIGH) {
if (buttonActiveR == false) {
buttonActiveR = true;
buttonTimerR = millis();
if ((millis() - buttonTimerR > longPressTimeR) && (longPressActiveR == false)) {
longPressActiveR = true;
delay(300);
if (buttonActiveR == true) {
if (longPressActiveR == true) {
currentScoreRight = currentScoreRight + 1;
delay(300);
// LEFT BUTTON CODE ******************************************************************
if (buttonStateLeft == HIGH) {
if (buttonActiveL == false) {
buttonActiveL = true;
buttonTimerL = millis();
if ((millis() - buttonTimerL > longPressTimeL) && (longPressActiveL == false)) {
longPressActiveL = true;
currentScoreLeft = 0;
delay(300);
if (buttonActiveL == true) {
if (longPressActiveL == true) {
currentScoreLeft = currentScoreLeft + 1;
delay(300);
Je vois l'affichage maintenant et les chiffres s'affichent à l'envers.
Il faudrait que je mette un miroir pour lire normalement les chiffres.
Je vous joins la photo si vous connaissez la solution,
Mais il y a un conflit avec l'instruction de faire reset avec un appui long sur le bouton.
Je vous joins le shéma qui était proposé sur le site original.
J'ai l'intuition qu'il est possible de les enlever.
Qu'en pensez vous?
Merci!
Je remets le dernier code corrigé avec votre qui fonctionne pour une meilleure compréhension:
// Use the MD_MAX72XX library to Print some text on the display
// Demonstrates the use of the library to print text.
// User can enter text on the serial monitor and this will display as a
// message on the display.
#include <SPI.h>
// Arbitrary pins
//MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
MD_MAX72XX mx = MD_MAX72XX(MD_MAX72XX::FC16_HW, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Text parameters
#define BUF_SIZE 75
uint8_t state = 0;
uint8_t curLen;
uint16_t showLen;
uint8_t cBuf[8];
switch(state)
if (*pMsg == '\0')
state = 2;
curLen = 0;
state++;
state = 2;
curLen = 0;
state++;
// fall through
curLen++;
state = 0;
default:
mx.begin();
//digitalWrite(BUTTON_LEFT_PIN, LOW);
// digitalWrite(BUTTON_RIGHT_PIN, LOW);
// Space Manager
howMuchSpace = " ";
howMuchSpace = " ";
howMuchSpace = " ";
howMuchSpace = " ";
howMuchSpace = " ";
delay(300);
delay(300);
if (currentScoreRight>12 || currentScoreLeft>12)
currentScoreRight=currentScoreLeft=0;
delay(300);
delay(300);
Il est possible d'enlever les résistances en activant le pullup interne avec INPUT_PULLUP.
Par contre tes boutons seront actifs à l'état bas.
Il suffit d'inverser la lecture
int buttonStateLeft = !digitalRead(BUTTON_LEFT_PIN);
int buttonStateRight = !digitalRead(BUTTON_RIGHT_PIN);
