Computer-on-module to go w/ arduino
I am looking to use an arduino mega to control a number of relays, poll and log sensors, etc. I have an EthernetSD shield but think that it will be limited to local logging to file, and serving those files to a ‘real’ database and web server; which I can also use to configure settings that the arduino reads from the sd card (I want the arduino to be able to run stand-alone). It looks like the ethernet shield cannot serve tcp/udp requests while it is accessing the SD card, which is annoying, so I expect I will need to find a way around this.
For the web and (lightweight) database server, can someone give me a recommendation for a cheap (1-200), fanless, low power option (and <=12VDC) capable of running linux with an ethernet port?
The beagle looks close but needs an expansion board to do ethernet.
{EDIT} - BeagleBoard-xM looks like a good option as it has ethernet. Anyone used it? Thoughts?
Cheers,
Lee
There was a recent thread about these in Bar Sport. Apparently they can be reflashed to a more-general-purpose version of Linux.
Looks like it's cheap, and similar to the sheevaplug. But I'd rather go with something less hacky as this is going into a prototype for a product.
Beagle and guruplug look like other options. But I've read disconcerting things about the quality of the guru plug, and overheating.
Hawkboard?
Ah - the hawkboard is interesting - cheaper and lower power than beagle. But the community support would tip me to beagle. Looks like I'll be waiting a while on the beagle Xm though...
