computer will not recognize port
output port on computer. I have loaded and uninstalled my program several times, but for what ever reason my Arduino uno will not connect to my port. I have used other devices and they work ok . The computer will not recognize the port no matter what port I use. I have followed all instructions to fix the port but with no progress . I have had computer problems , however they have been rectified.
Any Ideas anyone?
what operating system, which Arduino, is it genuine or a copy?
Which IDE are you using?
Peter
Please READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
- Always provide as much detail as possible to your issue it may be important.
- If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
- If applicable provide a schematic even if hand drawn.
- How to insert a picture into your post
COMMON ISSUES
- Check you have a COMMON GROUND where required.
- Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
- Try other computers where possible.
- Try other USB leads where possible.
- You may not have the correct driver installed. CH340/341 or CP2102
- There may be a problem with the board check your wiring first.
- Remove any items connected to pins 0 and 1.
COMPUTER RELATED
- Ensure you turn off any additional security / antivirus just to test.
- There may be a problem with the PC try RESTARTING it.
- You may be selecting the wrong COM port.
- Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
- Clear your browsers CACHE.
- Close the IDE before using any other serial programs.
- Preferably install IDE's as ADMINISTRATOR or your OS equivalent
Performing the above actions may help resolve your problem without further help.
Bob.
