Comunicate wireles with a sensor
I want to know if it's possible to for example:
(Sensor(for example MPU6500+bluetooth+baterie)*N ----communicate to---> Arduino + bluetooth
Or you can't send the raw output of the mpu via bluetooth???
Curbal: (Sensor(for example MPU6500+bluetooth+baterie)*N ----communicate to---> Arduino + bluetooth
If the sensor outputs a serial signal then it can likely be used directly with a Bluetooth module. I2C sensors will probably require a microcontroller to read the sensor and then relay the data to the Bluetooth module.
