I made a small weather station with two SX1276, simple hardware no problem.The receiver is driven by an Arduino UNO.I wanted to apply an SD card on this to record data but knowing that it could conflict with LoRa SX1276 which uses the same pin I looked up and saw that another CS pin could be assigned to the SD via software. Found a solution on the forum I made the sketch but it doesn't work. It tells me that the SD card is active and when it waits to receive the data it nails them and does not go forward.
#include <Vcc.h>
const float VccMin = 0.0; // Minimum expected Vcc level, in Volts.
const float VccMax = 5.0; // Maximum expected Vcc level, in Volts.
const float VccCorrection = 1.0/1.0; // Measured Vcc by multimeter divided by reported Vcc
Vcc vcc(VccCorrection);
#include <SimpleDHT.h>
SimpleDHT22 dht22(A0);
#include <Wire.h>
#include <SPI.h>
#include <LoRa.h>
#include <SD.h> // SD library
// Used for software SPI
#define LoRa_CLK 13
#define LoRa_MISO 12
#define LoRa_MOSI 11
// Used for hardware & software SPI
#define LoRa_CS1 10
#define SD_SCK 13
#define SD_MISO 12
#define SD_MOSI 11
#define SD_CS2 8
// software SPI
//LoRa = (LoRa_CS1, LoRa_MOSI, LoRa_MISO, LoRa_CLK);
//SD sd(SD_CS2, SD_MOSI, SD_MISO, SD_SCK); // software SPI
int CS1= 10;
int CS2= 8;
File file; // file object that is used to read and write data
float temperature = 0;
float humidity = 0;
dht22.read2(&temperature, &humidity, NULL);
Serial.println(" DATI INTERNO");
Serial.println("");
Serial.print("Temperature: ");Serial.print ((float)temperature); Serial.println(" C");
Serial.print("Humidity: ");Serial.print((float)humidity); Serial.println(" RH%");
Serial.println("");
float v = vcc.Read_Volts();
Serial.print("VCC = ");
Serial.print(v);
Serial.println(" Volts");
float p = vcc.Read_Perc(VccMin, VccMax);
Serial.print(p);
Serial.println(" %");
Serial.println("");
LoRa.begin(CS1);
if (!LoRa.begin(CS1)){
Serial.println("Starting LoRa failed!");
while (1);
Serial.println("LoRa Receiver waiting...");
LoRa.begin(CS1);
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
Serial.println("Received packet: ");
// read packet
while (LoRa.available()) {
Serial.print((char)LoRa.read());
//LoRa.end();
delay(10);
void writeFile() //writing something to the SD card
if (!SD.begin(CS2)) { // Initialize SD card
Serial.println("Errore SD");
return;
Serial.println("SD pronta");
Serial.println("");
if (SD.exists("file.txt")) {
SD.remove("file.txt");
file = SD.open("file.txt", FILE_WRITE); // open "file.txt" to write data; make sure that you want to write in the same file that you created in the setup()
if (file) {
file.println((char)LoRa.read()); // write number to file; in this case, the temperature with 2 decimals precision
file.close(); // close file
Serial.println("Could not open file (writing).");
