Hi! i´m a beginner, recently i bought the APC220 module.
But i can´t make it work, i followed this steps:
1- Download drivers
- "CP210x VCP Drivers" -> http://www.silabs.com/products/interface/Pages/interface-software.aspx
- "Driver USB" -> http://www.ctmelectronica.com.ar/index.php/descargas/descargas/software/driver-usb/detail
2- Download the configuration module software
- "RF-MagicV1.2A" -> http://www.ctmelectronica.com.ar/index.php/descargas/descargas/software/rf-magic-v1-2a/detail
3- Connect the module to the USB adapter, which as you can see in the picture, brings to connect 7 pins (I've seen, others, only have 6 and left the pin module "Set" off, I to have 7 the I all connected).
The computer recognizes the device and installs and assigns port "COM 5"
4- Open RF-MagicV1.2A program, check Finding and give dipositive "Write" to upload the configuration to the module, this, I have done with the 2 modules, i don ´t know if it is correct.
5- Connect a module to the arduino mega2560 board
GND -------> GND
VCC -------> 5V
RXD -------> TX0
TXD -------> RX0
6- Upload the sketch with the USB this code
int val = 0;
int ledPin = 13;
pinMode( ledPin, OUTPUT );
val = Serial.read();
if (-1 != val) {
if ('A' == val || 'a' == val) {
Serial.println("Hello from Arduino!");
}else if ('B' == val || 'b' == val) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
7- Disconnect USB and insert module+USB adapter to PC
8- Connect arduino to an external power 7.5V to "Vin" and "GND"
9- Enter in monitor serial and send "bbb", but the led remains off.
I hope you can help me,THANKS!
