Comunication PC-BLUETOOTH
Hi guys, I have a module bluetooth with connect with my PC and for that I use the terminal PuttY and everything is fine. My question is to known if is possible and how I can create a program in C, C#, java,.. that receive the data from the bluetooth and I can use them in one expression or make a register of data without use Putty. Thanks!
You can try using Processing. http://www.processing.org/
I uses a similar IDE but the code runs on your PC.
A simple serial read example:
 * Simple Read
 * Read data from the serial port and change the color of a rectangle
 * when a switch connected to a Wiring or Arduino board is pressed and released.
 * This example works with the Wiring / Arduino program that follows below.
import processing.serial.*;
Serial myPort;  // Create object from Serial class
int val;      // Data received from the serial port
  size(200, 200);
  // I know that the first port in the serial list on my mac
  // is always my  FTDI adaptor, so I open Serial.list()[0].
  // On Windows machines, this generally opens COM1.
  // Open whatever port is the one you're using.
  String portName = Serial.list()[1];
  myPort = new Serial(this, portName, 9600);
void draw()
  if ( myPort.available() > 0) {  // If data is available,
    val = myPort.read();         // read it and store it in val
    println(val);
  background(255);             // Set background to white
  if (val == 0) {              // If the serial value is 0,
    fill(0);                   // set fill to black
  else {                       // If the serial value is not 0,
    fill(204);                 // set fill to light gray
  rect(50, 50, 100, 100);
Sample code for the Arduino to send to Processing:
// Wiring / Arduino Code
// Code for sensing a switch status and writing the value to the serial port.
int switchPin = 4;                       // Switch connected to pin 4
  pinMode(switchPin, INPUT);             // Set pin 0 as an input
  Serial.begin(9600);                    // Start serial communication at 9600 bps
  if (digitalRead(switchPin) == HIGH) {  // If switch is ON,
    Serial.write(1);               // send 1 to Processing
  } else {                               // If the switch is not ON,
    Serial.write(0);               // send 0 to Processing
  delay(100);                            // Wait 100 milliseconds
If puttY is working than any language should work that supports a serial library. Just open the serial port comNN as in PuttY. On your PC Bluetooth just looks like a serial port. Which language? C, C++, C#, Java, Python, Basic, ....
Joe
[quote author=joe mcd link=topic=170699.msg1269290#msg1269290 date=1370568995] If puttY is working than any language should work that supports a serial library. Just open the serial port comNN as in PuttY. On your PC Bluetooth just looks like a serial port. Which language? C, C++, C#, Java, Python, Basic, ....
Joe [/quote]
Then what you say is if I create one program in C for example only I´ve to do is add a library in my program and run at the same time the programe and the PuttY to read from bluetooth? Any example code of how can I do that? Normally I use C but I can make in C++, C# or Java too
hiduino: You can try using Processing. http://www.processing.org/
Im will try that too ;)
C will work great. All you need to do is open the same serial port that putty was using. Note that you do NOT run putty at the same time. The first program to open the port also locks it. As far a C is concerned the Bluetooth port looks like a sequential file. Remember that putty is written in C.
A quick search gives many examples. Here are 2.
http://forums.codeguru.com/showthread.php?500130-Open-Serial-Port-using-C http://www.codeproject.com/Articles/2682/Serial-Communication-in-Windows
Joe
Thanks for all the help, I solved my problem using processing, the program is really awesome! Thanks guys!
