Comunication WIFI with Arduino
Hi my friends,
I want to make a system with two Arduino and I want that them will comunicate through wifi.
I want to use:
  • 1 Arduino Mega with wifi shield
  • 1 Arduino UNO with shield NRF24L01
My question is, can I make to comunicate this different shields?
Thanks.
No
Hi
I haven't tested it jet but normaly it must work.
An simple example will show what I mean:
You have bouhgt 2 wifisticks for your computer but they are from to different labels, but you can also move some files between the to cumputers.
At this special problem, I'm not sure if NRF24L01 can just go into an wifi network.
For this problem, there is allready an discussion on Arduino-forum:
http://forum.arduino.cc/index.php?topic=187274.0
But if you're sure that you can use this to components for wifi it should work.
The NRF24L01 is 2.4 GHz but NOT WiFi. It cannot communicate with a WiFi network.
Oh ok, but can I use one shield WiFi e one shield NFR24L01 on the Arduino Mega?
rossotony88:
The first step is to look at the specifications for both shields to see if one or both come with stacking headers (pins below the board and sockets above) and what pins they use and how. To do that you need to decide exactly which shields you want to use.
The official Arduino WiFi Shield has stacking headers.
http://arduino.cc/en/Main/ArduinoWiFiShield
It uses pins 4 (for SD card), 7, 10, and the SPI pins (11,12,13 on the UNO or 50-53 on the Mega)
The NRF24L01 shield is harder to pin down since there is no "official" model. Here is one from 'elechouse':
http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=74&products_id=2245
It has stacking headers but does not cover all pins so you should still put the WiFi shield on the bottom.
It uses the SPI pins (which can be shared so that's OK).
It uses Pins 2, 3, and 4 for INT, CE, and 'CSN' whatever that is. That should be O.K. as long as you don't use a SD card in the WiFi Shield.
Two very low cost WIFI Module ESP8266 ~$4 MT7681 ~$8
http://forum.arduino.cc/index.php?topic=276373.msg1956045#msg1956045
But this module use the PIN 0 and 1 (RX and TX) of Arduino. After how can I program Arduino?
  1. Program the Arduino
  2. connect the module
