ciao ragazzi, ho arduino mega, ho collegato un convertitore usb-rs232 e poi un max232 alimnetato a 5 volt, e tx rx collegati ai pin 0- 1 seguendo questo schetck...funziona se invio 1 o 0 da serial monitor . ma non riesco a far comunicare con i relativi pin.
sbaglio qualcosa?
ecco :
#include <SoftwareSerial.h>
SoftwareSerial PortaSeriale = SoftwareSerial(0, 1);
int ledPin = 52; // the number of the LED pin
pinMode(0, INPUT);
pinMode(1, OUTPUT);
Serial.begin(9600); // set serial speed
pinMode(ledPin, OUTPUT); // set LED as output
digitalWrite(ledPin, LOW); //turn off LED
void loop(){
while (Serial.available() == 0); // do nothing if nothing sent
int val = Serial.read() - '0'; // deduct ascii value of '0' to find numeric value of sent number
if (val == 1) { // test for command 1 then turn on LED
Serial.println("LED on");
digitalWrite(ledPin, HIGH); // turn on LED
else if (val == 0) // test for command 0 then turn off LED
Serial.println("LED OFF");
digitalWrite(ledPin, LOW); // turn off LED
else // if not one of above command, do nothing
//val = val;
Serial.println(val);
Serial.flush(); // clear serial port
