Comunicazione usb host shield e joystick ps3
Salve a tutti. Da poco ho comprato un arduino mega adk rev 3, un usb host shied http://www.ebay.it/itm/251290614945?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 e un mini adattatore usb dongle http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=150695080844 Attacco l'usb host shield ad arduino mega e poi l'usb dongle alla porta usb del modulo. Fin qui tutto bene. Ma quando vado a far connettere il joystick della ps3 ai componenti detti non succede nulla.
PS nell'arduino ho cricato il programma:
#include <PS3BT.h>
#include <usbhub.h>
USB Usb;
USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
//PS3BT PS3(&Btd,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
boolean printTemperature;
boolean printAngle;
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while(1); //halt
Serial.print(F("\r\nPS3 Bluetooth Library Started"));
Usb.Task();
if(PS3.PS3Connected || PS3.PS3NavigationConnected) {
if(PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
Serial.print(F("\r\nLeftHatX: "));
Serial.print(PS3.getAnalogHat(LeftHatX));
Serial.print(F("\tLeftHatY: "));
Serial.print(PS3.getAnalogHat(LeftHatY));
if(!PS3.PS3NavigationConnected) {
Serial.print(F("\tRightHatX: "));
Serial.print(PS3.getAnalogHat(RightHatX));
Serial.print(F("\tRightHatY: "));
Serial.print(PS3.getAnalogHat(RightHatY));
//Analog button values can be read from almost all buttons
if(PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
Serial.print(F("\r\nL2: "));
Serial.print(PS3.getAnalogButton(L2));
Serial.print(F("\tR2: "));
Serial.print(PS3.getAnalogButton(R2));
if(PS3.getButtonClick(PS)) {
Serial.print(F("\r\nPS"));
PS3.disconnect();
else {
if(PS3.getButtonClick(TRIANGLE))
Serial.print(F("\r\nTraingle"));
if(PS3.getButtonClick(CIRCLE))
Serial.print(F("\r\nCircle"));
if(PS3.getButtonClick(CROSS))
Serial.print(F("\r\nCross"));
if(PS3.getButtonClick(SQUARE))
Serial.print(F("\r\nSquare"));
if(PS3.getButtonClick(UP)) {
Serial.print(F("\r\nUp"));
if(PS3.PS3Connected) {
PS3.setAllOff();
PS3.setLedOn(LED4);
if(PS3.getButtonClick(RIGHT)) {
Serial.print(F("\r\nRight"));
PS3.setAllOff();
PS3.setLedOn(LED1);
if(PS3.getButtonClick(DOWN)) {
Serial.print(F("\r\nDown"));
PS3.setAllOff();
PS3.setLedOn(LED2);
if(PS3.getButtonClick(LEFT)) {
Serial.print(F("\r\nLeft"));
PS3.setAllOff();
PS3.setLedOn(LED3);
if(PS3.getButtonClick(L1))
Serial.print(F("\r\nL1"));
if(PS3.getButtonClick(L3))
Serial.print(F("\r\nL3"));
if(PS3.getButtonClick(R1))
Serial.print(F("\r\nR1"));
if(PS3.getButtonClick(R3))
Serial.print(F("\r\nR3"));
if(PS3.getButtonClick(SELECT)) {
Serial.print(F("\r\nSelect - "));
Serial.print(PS3.getStatusString());
if(PS3.getButtonClick(START)) {
Serial.print(F("\r\nStart"));
printAngle = !printAngle;
if(printAngle) {
Serial.print(F("\r\nPitch: "));
Serial.print(PS3.getAngle(Pitch));
Serial.print(F("\tRoll: "));
Serial.print(PS3.getAngle(Roll));
else if(PS3.PS3MoveConnected) {
if(PS3.getAnalogButton(T)) {
Serial.print(F("\r\nT: "));
Serial.print(PS3.getAnalogButton(T));
PS3.disconnect();
else {
Serial.print(F("\r\nSelect"));
printTemperature = !printTemperature;
if(PS3.getButtonClick(TRIANGLE)) {
Serial.print(F("\r\nTriangle"));
PS3.moveSetBulb(Red);
if(PS3.getButtonClick(CIRCLE)) {
PS3.moveSetBulb(Green);
if(PS3.getButtonClick(SQUARE)) {
PS3.moveSetBulb(Blue);
if(PS3.getButtonClick(CROSS)) {
PS3.moveSetBulb(Yellow);
if(PS3.getButtonClick(MOVE)) {
PS3.moveSetBulb(Off);
Serial.print(F("\r\nMove"));
Serial.print(F(" - "));
if(printAngle) {
else if(printTemperature) {
Serial.print(F("\r\nTemperature: "));
Serial.print(PS3.getTemperature());
