conbination of two codes.
Hello community.
I have found this two great projects. both of them work really great but now i would like to conbine them together.
i am thinking of creating a function of the seccond one and place it to the first one at the transmit proccess.
the first
http://www.instructables.com/files/orig/FWO/R38I/HQ9VUU35/FWOR38IHQ9VUU35.ino
that does this Old-School Texting with Arduino - YouTube
the seccond one encodes and decodes morse code from serial.
https://code.google.com/p/morse-endecoder/downloads/list
both of them work grate.
i modified the code to the second one
input pin is A0
pin 13 is still an output, and the rest of the keypad and lcd is like this schematichttp://www.instructables.com/file/FE2YQ8CHQ9REUHT/?size=LARGE
now, how can i make my Arduino uno to play morse code instead of writing at serial port window, what ever i had wrote to my lcd ?
any kind of help more than welcome.
thanks
Post your code(s) (using code tags, the hash button above the input box) here.
i did but one of them is way to big to fit . sad !
#include <LiquidCrystal.h> //include the lcd library
const byte row1=3; //keypad row pins, shared with the lcd data lines
const byte row2=4;
const byte row3=5;
const byte row4=6;
const byte col1=7; //keypad column lines
const byte col2=8;
const byte col3=9;
const byte col4=10;
LiquidCrystal lcd(12, 11, row4, row3, row2, row1); //lcd object
byte numpressed; //latest number pressed on the keypad
byte timespressed; //times the number has been pressed
byte cursorx=0; //cursor x position
byte cursory=0; //cursor y position
char letter; //stores letter that needs to be printed to the lcd
const int wait=1000; //time to wait for additional presses to same number
const int preventholddelay=150; //time to wait to prevent cycling through things too quickly
unsigned long basetime; //base time for while loop
unsigned long elapsed=0; //elapsed time in while loop
byte lastnumpressed; //the initial number pressed on the keypad
bool disablespacedelay=false; //disables the delay in the space function in the case that a different number is pressed while in while loop
const byte maxtimespressed[16]={
  1,3,4,4,4,4,4,4,4,4,1,7,1,1,1,1}; //stores maximum number of times any given key can be pressed before looping back to its first letter (used by incrementtimespressed function)
char typedtext[140]; //stores typed text for printout to the serial console
int positionintypedtext=0; //position in typedtext character array
int charremaining; //remaining characters in message
bool promptkeypress=false; //used for waiting for, and keypress detection, at the end-of composition prompt
void setup(){
  Serial.begin(115200); //start serial communication so that we can print the typed text to the serial console
  lcd.begin(16,2); //initialize the lcd
  lcd.setCursor(cursorx,cursory); //set the lcd cursor
  lcd.noCursor(); //turn off the cursor
  pinMode(row1,OUTPUT); //set the rows as outputs
  pinMode(row2,OUTPUT);
  pinMode(row3,OUTPUT);
  pinMode(row4,OUTPUT);
  pinMode(col1,INPUT); //set the  columns as inputs
  pinMode(col2,INPUT);
  pinMode(col3,INPUT);
  pinMode(col4,INPUT);
  delay(wait);
  lcd.cursor(); //turn the cursor on again after a delay equivalent to wait
  rowshigh(); //sets all rows high
void loop(){
  numpressed=16; //reset "numpressed" (16 doesn't refer to any button on the pad)
  if (findpress()){ //look for presses, if one has occurred, identify it and continue
    timespressed=0; //reset "timespressed"
    if (numpressed==0){ //if zero on the pad was pressed,
      dozero(); //print zero
      letter='0'; //manually seed a zero as the character for the text storage
      textstorage(1); //regular character storage
    if (numpressed==10){ //if shift on the pad was pressed,
      textstorage(2); //perform a space in storage
      dospace(); //do a space
    if (numpressed==14){ //if the arrows on the pad were pressed,
      textstorage(3); //perform a backspace in storage
      dobackspace(); //do a backspace
    if (numpressed==15){ //if enter on the pad was pressed,
      outputserial(); //output message and display remaining characters to serial console
    if ((numpressed<10&&numpressed>0)||numpressed==11){ //if 1,2,3,4,5,6,7,8,9, or 11 was pressed (any one of the keys with multiple characters assigned),
      lastnumpressed=numpressed; //record which number was pressed,
      basetime=millis(); //and take a base time for the while loop
      while (elapsed<wait){ //while below the time to wait,
        if(findpress()){ //look for presses, if one has occurred, identify it and continue
          if (numpressed==lastnumpressed){ //if it was the same as before,
            incrementtimespressed(); //increment "timespressed"
            basetime=basetime+(wait-(wait-elapsed)); //roll up the base time, to allow another wait period until next press of the same button
            definepress(); //use "numpressed" and "timespressed" to define "letter"
            lcd.print(letter); //print the letter that was defined
            lcd.setCursor(cursorx,cursory); //maintain cursor position
            rowshigh(); //return all rows high
            delay(preventholddelay); //delay a little to prevent continuous cycling through "timespressed" during a single press
          else{ //if the number that was pressed was different than before,
            disablespacedelay=true; //disable the delay in the space function to allow the press to be detected a second time, at the beginning of void loop
            break; //break out of the while loop
        elapsed=millis()-basetime; //refresh the elapsed time for the while loop
      elapsed=0; //reset the elapsed time for the while loop
      textstorage(1); //store character
  if (positionintypedtext==139){ //if the end of the stored text has been reached,
    promptkeypress=false; //reset keypress detection
    cursorx=0; //set cursor to the beginning of first row
    cursory=0;
    lcd.print("Msg end. <>=back"); //print this out to the lcd
    cursorx=0; //set cursor to the beginning of second row
    cursory=1;
    lcd.print("enter=serial out"); //print this out to the lcd
    while(!promptkeypress){ //while no relevant keypresses have occurred,
          promptkeypress=true; //take note so that the while loop can be broken
          for (int i=0;i<16;i++){ //print out to the first line on the lcd from the stored text
            cursorx=i;
            cursory=0;
            lcd.print(typedtext[108+i]);
          for (int j=0;j<16;j++){ //print out to the second line on the lcd from the stored text
            cursorx=j;
            cursory=1;
            lcd.print(typedtext[123+j]);
          cursorx=15; //set cursor to the beginning of second row
          cursory=1;
          Serial.print("Final message: "); //print this to the serial console
          Serial.println(typedtext); //print out all the text typed so far to the serial console
          Serial.println(); //print a blank line
          for (int i=0;i<140;i++){ //write all positions in the stored text to be blank
            typedtext[i]=' ';
          positionintypedtext=0; //reset the position in the stored text to the beginning
          doclear();
void rowshigh(){ //sets all rows high
  digitalWrite(row1,HIGH); //write all the rows high
  digitalWrite(row2,HIGH);
  digitalWrite(row3,HIGH);
  digitalWrite(row4,HIGH);
bool findpress(){ //finds a press to define "numpressed", if any press occurs, returns true
  bool pressfound=false; //variable for any press detection, is returned by this function
  digitalWrite(row1,LOW); //write all rows low
  digitalWrite(row2,LOW);
  digitalWrite(row3,LOW);
  digitalWrite(row4,LOW);
  digitalWrite(row1,HIGH); //write first row high
  if (digitalRead(col1)==HIGH){ //if the first column is now high, "1" has been pressed
    numpressed = 1;
    pressfound=true;
  if (digitalRead(col2)==HIGH){ //if the second column is now high, "2" has been pressed
    numpressed = 2;
    pressfound=true;
  if (digitalRead(col3)==HIGH){ //if the third column is now high, "3" has been pressed
    numpressed = 3;
    pressfound=true;
  if (digitalRead(col4)==HIGH){ //if the fourth column is now high, "reset" has been pressed
    numpressed = 12;
    pressfound=true;
  digitalWrite(row1,LOW); //return first row low
  digitalWrite(row2,HIGH); //write second row high
  if (digitalRead(col1)==HIGH){ //if the first column is now high, "4" has been pressed
    numpressed = 4;
    pressfound=true;
  if (digitalRead(col2)==HIGH){ //if the second column is now high, "5" has been pressed
    numpressed = 5;
    pressfound=true;
  if (digitalRead(col3)==HIGH){ //if the third column is now high, "6" has been pressed
    numpressed = 6;
    pressfound=true;
  if (digitalRead(col4)==HIGH){ //if the fourth column is now high, "dial" has been pressed
    numpressed = 13;
    pressfound=true;
  digitalWrite(row2,LOW); //return second row low
  digitalWrite(row3,HIGH); //write third row high
  if (digitalRead(col1)==HIGH){ //if the first column is now high, "7" has been pressed
    numpressed = 7;
    pressfound=true;
  if (digitalRead(col2)==HIGH){ //if the second column is now high, "8" has been pressed
    numpressed = 8;
    pressfound=true;
  if (digitalRead(col3)==HIGH){ //if the third column is now high, "9" has been pressed
    numpressed = 9;
    pressfound=true;
  if (digitalRead(col4)==HIGH){ //if the fourth column is now high, the arrows have been pressed
    numpressed = 14;
    pressfound=true;
  digitalWrite(row3,LOW); //return third row low
  digitalWrite(row4,HIGH); //write fourth row high
  if (digitalRead(col1)==HIGH){ //if the first column is now high, "shift" has been pressed
    numpressed = 10;
    pressfound=true;
  if (digitalRead(col2)==HIGH){ //if the second column is now high, "0" has been pressed
    numpressed = 0;
    pressfound=true;
  if (digitalRead(col3)==HIGH){ //if the third column is now high, "." has been pressed
    numpressed = 11;
    pressfound=true;
  if (digitalRead(col4)==HIGH){ //if the fourth column is now high, "enter" has been pressed
    numpressed = 15;
    pressfound=true;
  digitalWrite(row4,LOW); //return fourth row low
  rowshigh(); //write all rows high
    return pressfound; //function returns true if any press found, otherwise returns false
void definepress(){ //uses "lastnumpressed" and "timespressed" to define "letter"
  if (lastnumpressed==1){
    if (timespressed==1){
      letter='Q';
    if (timespressed==2){
      letter='Z';
    if (timespressed==3){
      letter='1';
  if (lastnumpressed==2){
      letter='A';
      letter='B';
      letter='C';
    if (timespressed==4){
      letter='2';
  if (lastnumpressed==3){
      letter='D';
      letter='E';
      letter='F';
      letter='3';
  if (lastnumpressed==4){
      letter='G';
      letter='H';
      letter='I';
      letter='4';
  if (lastnumpressed==5){
      letter='J';
      letter='K';
      letter='L';
      letter='5';
  if (lastnumpressed==6){
      letter='M';
      letter='N';
      letter='O';
      letter='6';
  if (lastnumpressed==7){
      letter='P';
      letter='R';
      letter='S';
      letter='7';
  if (lastnumpressed==8){
      letter='T';
      letter='U';
      letter='V';
      letter='8';
  if (lastnumpressed==9){
      letter='W';
      letter='X';
      letter='Y';
      letter='9';
  if (lastnumpressed==11){
      letter='.';
      letter='?';
      letter='!';
      letter=',';
    if (timespressed==5){
      letter='\'';
    if (timespressed==6){
      letter='"';
    if (timespressed==7){
      letter='-';
void incrementtimespressed(){ //increment "timespressed" until at max value stored in maxtimespressed for that lastnumpressed, then roll over to 1
  if (timespressed==maxtimespressed[lastnumpressed]){ //if at the maximum,
    timespressed=1; //roll over timespressed to one
  else{ //otherwise,
    timespressed++; //increment timespressed
void dozero(){ //prints zero
  lcd.print('0'); //print 0
  dospace(); //space
void dospace(){ //moves cursor forward once, wraps to next line if necessary, clears and returns to top of display if at bottom
  if (cursory==1){ //if on the bottom row,
    if (cursorx==15){ //if at the end of the row,
      cursorx=0; //define new cursor position as the upper-left corner
      cursory=0;
      lcd.clear(); //clear the lcd
    else{ //otherwise,
      cursorx++; //increment the cursor to the right
  else{ //if on the top row,
      cursorx=0; //define new cursor position as the bottom-left corner
      cursory=1;
    else{ //otherwise,
  lcd.setCursor(cursorx,cursory); //set cursor to defined location
  if (disablespacedelay){ //if the delay has been disabled,
    disablespacedelay=false; //reset its being disabled
  else{ //otherwise,
    delay(preventholddelay); //delay a bit
void doclear(){ //clears and returns to top-left of display
  cursorx=0;
  cursory=0;
  lcd.clear();
void dobackspace(){ //does a backspace, essentially the opposite of dospace
  if (cursory==1){
    if (cursorx==0){
      cursorx=15;
      cursory=0;
    else{
      cursorx--;
  else{
    if (cursorx==0){
      cursorx=0;
      cursory=0;
    else{
      cursorx--;
  lcd.print(" ");
void textstorage(byte mode){ //contains functions for text storage
  if (mode==1){ //regular character storage
    typedtext[positionintypedtext]=letter; //store letter that was printed to LCD in typedtext
    positionintypedtext++; //increment position in typedtext
  if (mode==2){ //do a space in stored text
    typedtext[positionintypedtext]=' '; //set current position in typedtext to a space
  if (mode==3){ //does a backspace in the stored text
    positionintypedtext--; //decrement position in typedtext
void outputserial(){ //output message and display remaining characters to serial console
  Serial.print("Message: ");
  charremaining=(139-(positionintypedtext)); //calculate remaining characters
  Serial.print(charremaining); //display remaining characters
  if (charremaining==1){ //making sure that the plural is only used correctly
    Serial.println(" character remaining");
  else{
    Serial.println(" characters remaining");
the three parts above are all one code. the texter.
and this is the morse encoder / decoder
                MORSE ENDECODER DEMO
  Demonstrates using Morse encoder and decoder classes for the Arduino.
  Local Morse code feedback to both serial and Morse output (unless sending
    at the same time as receiving or keying in morse), for morse training demo.
  Formatted serial port output - Serial monitor looks a bit nicer.
  This example decodes Morse code signals with a speed of 13 WPM present on
    digital input 7 (active low, and also using the internal pullup resistor).
  It also encodes Morse code sent via the serial interface to the Arduino,
    on digital output pin 13. Speed is 13 WPM also (easily changed in code).
  It can also decode audible signals, if using the constant MORSE_AUDIO
    instead of MORSE_KEYER, but then it is important to note that the
    input pin nr. will be for ANALOG inputs (0-5 on Atmega 168 - 328),
    and not the digital inputs.
  Copyright (C) 2010, 2012 raron
  GNU GPLv3 license:
  This program is free software: you can redistribute it and/or modify
  it under the terms of the GNU General Public License as published by
  the Free Software Foundation, either version 3 of the License, or
  (at your option) any later version.
  This program is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  GNU General Public License for more details.
  You should have received a copy of the GNU General Public License
  along with this program.  If not, see <http://www.gnu.org/licenses/>.
  Contact: raronzen@gmail.com  (not checked too often..)
  Details: http://raronoff.wordpress.com/2010/12/16/morse-endecoder/
#include <avr/pgmspace.h>
#include <MorseEnDecoder.h>
// Pin mappings
const byte morseInPin = 7;
const byte morseOutPin = 13;
// Instantiate Morse objects
morseDecoder morseInput(morseInPin, MORSE_KEYER, MORSE_ACTIVE_LOW);
morseEncoder morseOutput(morseOutPin);
// Variables dealing with formatting the output somewhat
// by inserting CR's (carriage returns)
long lastTransmissionTime;
long currentTime;
boolean transmissionEnded = true; // Flag to mark old transmission is finished
// Minimum transmission pause time to insert carriage returns (CR)
// Adjust depending on Morse speed. IE 13 wpm = 646 ms between words (no CR).
const long transmissionPaused   = 1000; // Suitable for 13 wpm?
  Serial.println("Morse EnDecoder demo");
  // Setting Morse speed in wpm - words per minute
  // If not set, 13 wpm is default anyway
  morseInput.setspeed(13);
  morseOutput.setspeed(13);
  lastTransmissionTime = (long)millis();
  currentTime = (long)millis();
  // Needs to call these once per loop
  morseInput.decode();
  morseOutput.encode();
  // SEND MORSE (OUTPUT)
  // Encode and send text received from the serial port (serial monitor)
  if (Serial.available() && morseOutput.available())
    // Get character from serial and send as Morse code
    char sendMorse = Serial.read();
    morseOutput.write(sendMorse);
    // Not strictly needed, but used to get morseSignalString before it is destroyed
    // (E.g. for morse training purposes)
    // Also write sent character + Morse code to serial port/monitor
    Serial.write(' ');
    Serial.write(sendMorse);
    Serial.write(morseOutput.morseSignalString);
  // RECEIVE MORSE (INPUT)
  // If a character is decoded from the input, write it to serial port
  if (morseInput.available())
    // Get decoded Morse code character and write it to serial port/monitor
    char receivedMorse = morseInput.read();
    Serial.print(receivedMorse);
    // A little error checking
    if (receivedMorse == '#') Serial.println("< ERROR:too many morse signals! >");
  // Local Morse code feedback from input if not sending Morse simultaneously
  if (morseOutput.available()) digitalWrite(morseOutPin, morseInput.morseSignalState);
  // Check if ongoing transmission (not yet transmission pause)
  if (!morseOutput.available() || morseInput.morseSignalState == true)
    // reset last transmission timer and flag
    lastTransmissionTime = currentTime;
    transmissionEnded = false;
  // Format output with carriage returns after a transmission pause
  if ((currentTime - lastTransmissionTime) > transmissionPaused)
    if (transmissionEnded == false)
      // Separate the transmissions somewhat in the serial monitor with CR's
      for (int cr=0; cr<2; cr++) Serial.println("");  // some carriage returns..
      // Finally set the flag to prevent continous carriage returns
i am thing of creating a function that loops 'for' the No. of chars "typedtext" has and do the decoder / encoder scetch.
i've tried to put text from "typedtext" to "sendMorse"
ORIGINAL CODE
MY TRY
 char sendMorse = typedtext;
but comes up with an error.
i am a little bit lost here.
any help would be more than welcome.
thanks for your time
ok ! managed to come up to a point with no compilation errors.
and this is the code that i came up with,
       char sendMorse = typedtext[i];
       Serial.println(sendMorse); // just to check if sendMorse has the date from typedtext.
sendMorse gets each and every one of the characters from typedtext but morse encode doesn's start on the speaker.
