Hello,
I have an RTC DS1307 attached to my Arduino Leonardo with the Ethernet/SD Shield. I want to use the hour, dayOfMonth, month and year variables to make a char array that look like this 16091012.txt (4pm in 09/10/2012--Today). This way i could create a file in the SD Card. I'm using
I tried to use strcpy and strcat, but the program stops responding before arriving to these instructions. when i delete them, the programs runs fine.
This also happens when using itoa function.
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68 // This is the I2C address
// Arduino version compatibility Pre-Compiler Directives
#if defined(ARDUINO) && ARDUINO >= 100 // Arduino v1.0 and newer
#define I2C_WRITE Wire.write
#define I2C_READ Wire.read
#else // Arduino Prior to v1.0
#define I2C_WRITE Wire.send
#define I2C_READ Wire.receive
#endif
// Global Variables
int command = 0; // This is the command char, in ascii form, sent from the serial port
int i;
long previousMillis = 0; // will store last time Temp was updated
int second, minute, hour, dayOfWeek, dayOfMonth, month, year;
byte test;
byte zero;
char *nombrearchivo, *hora, *dia, *mes, *ano;
// initialize the library with the numbers of the interface pins
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers, Probably need to put in checks for valid numbers.
void setDateDs1307()
second = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
minute = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
hour = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
dayOfWeek = (byte) (Serial.read() - 48);
dayOfMonth = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
month = (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
year= (byte) ((Serial.read() - 48) *10 + (Serial.read() - 48));
Wire.beginTransmission(DS1307_I2C_ADDRESS);
I2C_WRITE(zero);
I2C_WRITE(decToBcd(second) & 0x7f); // 0 to bit 7 starts the clock
I2C_WRITE(decToBcd(minute));
I2C_WRITE(decToBcd(hour)); // If you want 12 hour am/pm you need to set
// bit 6 (also need to change readDateDs1307)
I2C_WRITE(decToBcd(dayOfWeek));
I2C_WRITE(decToBcd(dayOfMonth));
I2C_WRITE(decToBcd(month));
I2C_WRITE(decToBcd(year));
Wire.endTransmission();
// Gets the date and time from the ds1307 and prints result
void getDateDs1307()
// Reset the register pointer
I2C_WRITE(zero);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
second = bcdToDec(I2C_READ() & 0x7f);
minute = bcdToDec(I2C_READ());
hour = bcdToDec(I2C_READ() & 0x3f); // Need to change this if 12 hour am/pm
dayOfWeek = bcdToDec(I2C_READ());
dayOfMonth = bcdToDec(I2C_READ());
month = bcdToDec(I2C_READ());
year = bcdToDec(I2C_READ());
if (hour < 10)
Serial.print('0');
Serial.print(hour, DEC);
Serial.print(":");
if (minute < 10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second < 10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(", ");
if (dayOfMonth < 10)
Serial.print('0');
Serial.print(dayOfMonth, DEC);
Serial.print(" ,");
Serial.print(month, DEC);
Serial.print(" 20");
if (year < 10)
Serial.print("0");
Serial.println(year);
//#####Concatenatestrins into filename######
Wire.begin();
Serial.begin(57600);
zero=0x00;
if (Serial.available()) { // Look for char in serial que and process if found
command = Serial.read();
if (command == 84 || command == 116) { //If command = "Tt" Set Date
//setDateDs1307();
getDateDs1307();
Serial.println(" ");
else if (command == 82 || command == 114) { //If command = "Rr" Read Date ... BBR
getDateDs1307();
else if (command == 81 || command == 113) { //If command = "Qq" RTC1307 Memory Functions
delay(100);
if (command == 49) { //If command = "1" RTC1307 Initialize Memory - All Data will be set to
// 255 (0xff). Therefore 255 or 0 will be an invalid value.
Wire.beginTransmission(DS1307_I2C_ADDRESS); // 255 will be the init value and 0 will be considered
// an error that occurs when the RTC is in Battery mode.
I2C_WRITE(0x08); // Set the register pointer to be just past the date/time registers.
for (i = 1; i <= 24; i++) {
I2C_WRITE(0Xff);
delay(10);
I2C_WRITE(0x21); // Set the register pointer to 33 for second half of registers. Only 32 writes per connection allowed.
for (i = 1; i <= 33; i++) {
I2C_WRITE(0Xff);
delay(10);
getDateDs1307();
Serial.println(": RTC1307 Initialized Memory");
else if (command == 50) { //If command = "2" RTC1307 Memory Dump
getDateDs1307();
Serial.println(": RTC 1307 Dump Begin");
I2C_WRITE(zero);
Wire.requestFrom(DS1307_I2C_ADDRESS, 32);
for (i = 0; i <= 31; i++) { //Register 0-31 - only 32 registers allowed per I2C connection
test = I2C_READ();
Serial.print(i);
Serial.print(": ");
Serial.print(test, DEC);
Serial.print(" : ");
Serial.println(test, HEX);
I2C_WRITE(0x20);
for (i = 32; i <= 63; i++) { //Register 32-63 - only 32 registers allowed per I2C connection
test = I2C_READ();
Serial.print(i);
Serial.print(": ");
Serial.println(" RTC1307 Dump end");
Serial.print("Command: ");
Serial.println(command); // Echo command CHAR in ascii that was sent
command = 0; // reset command
delay(100);
This is a code for RTC that i found. I want to use the function getDateDs1307(), this way i'll have the hour,dayOfMonth, month and year in integer variables.
What i need is like
char filedate[13]="16091012.txt"
Any ideas?
Thank you!
