concatenate integers
Hey guys.
I have been looking for a solution to concatenate integers but haven't found anything that works.
I have 2 integers. 1st int is a constant-- int x = 49. 2nd int is a number that varies-- int y = random(0,1024). I want to save this to a 3rd location-- int z= x,y. Example at both extremes of y. z = 490 or 491024
int x=49;
int y=0;
int z=0;
  y= random(0,1024);
//need concatenate code here
  Serial.print ("Y is   ");
  Serial.println (y);
  Serial.print ("Z is   ");
  Serial.println (z);// should be 49 followed by a random number between 0-1024
  delay(2000);
Hope someone can help. Thanks
int x = 49;
int y = 0;
//int z=0;
long z = 0;
  y = random(0, 1024);
  if (y < 10)
    z = (x * 10) + y;
  else if (y < 100)
    z = (x * 100) + y;
  else if (y < 1000)
    z = (x * 1000L) + y;
  else z = (x * 10000L) + y;
  Serial.println (y);
  delay(2000);
int x=49;
int y=0;
long int z=0;
  y= random(0,1024);
  z = x;
  do {
    z = z * 10;
  } while (z < 100L * y);
  z += y;
  Serial.println (y);
  delay(2000);
But do note the version of Paul fails if you change x to something with more digits. If it’s indeed fixed to be 49 you’re good to go.
Otherwise:
int x=49;
int y=0;
unsigned int z=0;
  y= random(0,1024);
  z = 1;
  do {
    z *= 10;
  } while (z <= y);
  z *= x;
  z += y;
  Serial.println (y);
  delay(2000);
ROVguy: Example at both extremes of y. z = 490 or 491024
The upper end of the "int" range is 32767. What about using "long" if you want numbers up to 491024?
Or just unsigned... Because all the code provided goes wrong when x is negative so yeay :p
septillion:
No, now I think about it, my code does not work quite correctly even for x=49. Use septilliion’s code!
PaulRB: No, now I think about it, my code does not work quite correctly even for x=49. Use septilliion's code!
Here is another code:
  const int x=49;
  int y= random(0,1024);
  char buf[11];
  snprintf(buf,sizeof(buf),"%d%d",x,y); // format 2 numbers as string
  long z= atol(buf); // revert string to a long number
  Serial.print ("Y= ");Serial.print(y);
  Serial.print ('\t');
  Serial.print ("Z= ");
  delay(2000);
BTW: The random number range of "random(0,1024);" is from 0 to 1023. 1024 is not included within that range.
"Sketch uses 4,574 bytes (14%) of program storage space."
vs
"Sketch uses 2,992 bytes (9%) of program storage space."
I think it's a bit overkill to use string functions like snprintf is a bit overkill here...
And yeay, the random() function is a bit weird... I find it not very logical the exclude the upper limit but okay, easy to fix :p
you can calculate the number directly without a loop:
in theory the solution is z = y + 49 * pow(10, 1 + floor(log10(y)));
in practice however you need one additional step…
long x = 49;
long y = 0;
long z = 0;
  for (int y = 1; y < 1024; y++)
    z = y + (49 * pow(10, 1 + floor(log10(y))));
    Serial.println (z);
    z = y + round(49 * pow(10, 1 + floor(log10(y))));
    Serial.println (z);
that said,
  1. in the integer domain a while loop is often more accurate and faster than the pow & log solution.
  2. the pow & log solution does not work for 0 and negative integers.
  3. the pow & log solution might increase the footprint.
