Concatenate Wire.read()
Hi…
I am trying to read 24bits from my ADC but the ADC only returns 8bits and print them onto a new line. It is important that I read all 24 bits in 1 single output so I can code the decoding of the ADC…Anyone knows how can this be done?
Thanks in Advance! :slight_smile:
#include <SPI.h>
#include <Wire.h>
#define ADCAddr 0x14         //Address of I2C
uint32_t data;
int dataBits;
int dataBits2;
uint8_t adcChannel[8] = { 0xB0, 0xB8, 0xB1, 0xB9,
                          0xB2, 0xBA, 0xB3, 0xBB };
  Wire.begin();
  Wire.beginTransmission(ADCAddr);
  Wire.write(0);
  Wire.write(adcChannel[0]);
  Wire.endTransmission();
  Serial.println("Welcome to BMS");
  for (int x = 0; x < 8; x++) {
    delay(170);
    Serial.print(adcChannel[x], HEX);
    Serial.println(":");
    Wire.write(adcChannel[x]);
    delay(170);
    Wire.requestFrom(ADCAddr, 3);
    while(Wire.available()) {
      data = Wire.read();
      Serial.println(data, BIN);
  // wait a second
Which ADC part? Why the big delay between reads?
The part will likely be perfectly happy to send out 3 bytes at once if you give it a command that supports that.
CrossRoads:
Hi Crossroads
I am using LTC2497.
I tried using the following,
if(Wire.available()<4) {
      data = Wire.read()<<16 | Wire.read()<<8 | Wire.read();
The problem is that whenever i do a 16bit shift, it returns 8 bits again
If your device supports “autoincrement” when reading 8 bit registers, this is one way people go about reading a 24 bit number from the I2C bus:
  Wire.beginTransmission(device_addr);
  Wire.write(reg_addr);  //send starting register address
  Wire.endTransmission(false); //restart for read
  Wire.requestFrom(device_addr, 3, true); //get three bytes and combine
  long data = ((long) Wire.read() << 16) | (Wire.read()<<8) | Wire.read();
The above assumes the high byte comes first. Make sure you know the correct order of low, medium and high byte values.
jremington:
The above assumes the high byte comes first. **Make sure** you know the correct order of low, medium and high byte values.
Hi jremington
I got it to work it was the “(long)” that was missing that caused it not to capture all the reading.
Thanks alot!
